Is there any framebuffer testcases?
Chris Johns
chrisj at rtems.org
Wed Apr 13 08:07:18 UTC 2016
On 08/04/2016 11:45, Chris Johns wrote:
> The test is simple:
> $ cat hw.c
> #include <stdio.h>
> int main(void)
> printf("hello world\n");
> return 0;
> $ arm-rtems4.12-gcc -o hw hw.c
The actual failing test case used by configure is attached. It would
seem changes to newlib or gcc have broken building 3rd party packages.
A fix would be nice. :)
Thanks
$ i386-rtems4.12-gcc -o conftest conftest.c
/opt/work/rtems/4.12/lib/gcc/i386-rtems4.12/6.0.0/../../../../i386-rtems4.12/bin/ld:
warning: cannot find entry symbol _start; defaulting to 0000000008048074
/opt/work/rtems/4.12/lib/gcc/i386-rtems4.12/6.0.0/../../../../i386-rtems4.12/lib/libc.a(lib_a-fclose.o):
In function `_fclose_r':
/opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fclose.c:117:
undefined reference to `_Mutex_recursive_Release'
/opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fclose.c:86:
undefined reference to `_Mutex_recursive_Acquire'
/opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fclose.c:91:
/opt/work/rtems/4.12/lib/gcc/i386-rtems4.12/6.0.0/../../../../i386-rtems4.12/lib/libc.a(lib_a-fflush.o):
In function `_fflush_r':
/opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fflush.c:282:
/opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fflush.c:280:
/opt/work/rtems/4.12/lib/gcc/i386-rtems4.12/6.0.0/../../../../i386-rtems4.12/lib/libc.a(lib_a-findfp.o):
In function `__fp_lock':
/opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/findfp.c:297:
In function `__fp_unlock':
/opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/findfp.c:308:
In function `__sinit_lock_acquire':
/opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/findfp.c:282:
In function `__sfp_lock_acquire':
/opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/findfp.c:270:
In function `__sfp_lock_release':
/opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/findfp.c:276:
In function `__sinit_lock_release':
/opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/findfp.c:288:
/opt/work/rtems/4.12/lib/gcc/i386-rtems4.12/6.0.0/../../../../i386-rtems4.12/lib/libc.a(lib_a-fopen.o):
In function `_fopen_r':
/opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fopen.c:152:
/opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fopen.c:170:
/opt/work/rtems/4.12/lib/gcc/i386-rtems4.12/6.0.0/../../../../i386-rtems4.12/lib/libc.a(lib_a-fseeko.o):
In function `_fseeko_r':
/opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fseeko.c:157:
/opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fseeko.c:141:
/opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fseeko.c:318:
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20160413/cb0ec62b/attachment-0002.bin>
