Is there any framebuffer testcases?
Wed Apr 13 14:14:40 UTC 2016
On Wed, Apr 13, 2016 at 8:43 AM, Sebastian Huber <
> On 13/04/16 15:36, Peng Fan wrote:
>> On Wed, Apr 13, 2016 at 12:51:54PM +0200, Sebastian Huber wrote:
>>> >On 13/04/16 12:33, Peng Fan wrote:
>>>> >>Ok. I see it. It was finally archived in to libscore.a. Please kindly
>>>> guide
>>>> >>me to fix this, I do not know where to begin.
>>> >Sorry, I didn't follow the thread. What is the problem?
>> As Chris posted,
>> The test is simple:
>>    $ cat hw.c
>>    #include <stdio.h>
>>    int main(void)
>>      printf("hello world\n");
>>      return 0;
>>    $ arm-rtems4.12-gcc -o hw hw.c
>> The actual failing test case used by configure is attached. It would seem
>> changes to newlib or gcc have broken building 3rd party packages.
>> $ i386-rtems4.12-gcc -o conftest conftest.c
>> /opt/work/rtems/4.12/lib/gcc/i386-rtems4.12/6.0.0/../../../../i386-rtems4.12/bin/ld:
>> warning: cannot find entry symbol _start; defaulting to 0000000008048074
>> /opt/work/rtems/4.12/lib/gcc/i386-rtems4.12/6.0.0/../../../../i386-rtems4.12/lib/libc.a(lib_a-fclose.o):
>> In function `_fclose_r':
>> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fclose.c:117:
>> undefined reference to `_Mutex_recursive_Release'
> Ok, we need probably some hacks in Newlib to make Autoconf happy in case
> you don't build against the proper RTEMS libraries.
As I posted a few messages back, based on what symbols were missing when I
did  a link on "whole library" libc.a and crt0.o, these were undefined that
wouldn't
come from libgcc*
_Mutex_Acquire
_Mutex_recursive_Acquire
_Mutex_Release
posix_memalign
They need to be in newlib/libc/sys/rtems/crt0.c.
It would be nice to have a repeatable way to check for missing symbols in
the
dummy crt0.c. I think my procedure was close but not 100%.
URL: <http://lists.rtems.org/pipermail/users/attachments/20160413/ceb96a5b/attachment-0001.html>
