Is there any framebuffer testcases?
Wed Apr 13 20:55:14 UTC 2016
Attached is a patch to newlib to add the symbols I think are needed.
Please let me know if this helps.
--joel
On Wed, Apr 13, 2016 at 9:14 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Apr 13, 2016 at 8:43 AM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 13/04/16 15:36, Peng Fan wrote:
>>> On Wed, Apr 13, 2016 at 12:51:54PM +0200, Sebastian Huber wrote:
>>>> >On 13/04/16 12:33, Peng Fan wrote:
>>>>> >>Ok. I see it. It was finally archived in to libscore.a. Please
>>>>> kindly guide
>>>>> >>me to fix this, I do not know where to begin.
>>>> >Sorry, I didn't follow the thread. What is the problem?
>>> As Chris posted,
>>> The test is simple:
>>>    $ cat hw.c
>>>    #include <stdio.h>
>>>    int main(void)
>>>      printf("hello world\n");
>>>      return 0;
>>>    $ arm-rtems4.12-gcc -o hw hw.c
>>> The actual failing test case used by configure is attached. It would seem
>>> changes to newlib or gcc have broken building 3rd party packages.
>>> $ i386-rtems4.12-gcc -o conftest conftest.c
>>> /opt/work/rtems/4.12/lib/gcc/i386-rtems4.12/6.0.0/../../../../i386-rtems4.12/bin/ld:
>>> warning: cannot find entry symbol _start; defaulting to 0000000008048074
>>> /opt/work/rtems/4.12/lib/gcc/i386-rtems4.12/6.0.0/../../../../i386-rtems4.12/lib/libc.a(lib_a-fclose.o):
>>> In function `_fclose_r':
>>> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fclose.c:117:
>>> undefined reference to `_Mutex_recursive_Release'
>> Ok, we need probably some hacks in Newlib to make Autoconf happy in case
>> you don't build against the proper RTEMS libraries.
> As I posted a few messages back, based on what symbols were missing when I
> did  a link on "whole library" libc.a and crt0.o, these were undefined
> that wouldn't
> come from libgcc*
> _Mutex_Acquire
> _Mutex_recursive_Acquire
> _Mutex_Release
> posix_memalign
> They need to be in newlib/libc/sys/rtems/crt0.c.
> It would be nice to have a repeatable way to check for missing symbols in
> the
> dummy crt0.c. I think my procedure was close but not 100%.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/users/attachments/20160413/9de4e2d5/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20160413/9de4e2d5/attachment.obj>
