Is there any framebuffer testcases?
Wed Apr 13 21:57:57 UTC 2016
On 13/04/2016 17:46, Peng Fan wrote:
> Hi Chris,
> I met this, so I add export INCLUDES=-I%{_includedir}:
I saw but I am concerned there is more to this. I think INCLUDES is
specific to automake.
> arm-rtems4.12-gcc -E -DHAVE_CONFIG_H -I. -I../libpng-1.6.21 \
>       -DPNGLIB_LIBNAME='PNG16_0' -DPNGLIB_VERSION='1.6.21'
> -DSYMBOL_PREFIX='' -DPNG_NO_USE_READ_MACROS -DPNG_BUILDING_SYMBOL_TABLE
>   pnglibconf.c > pnglibconf.tf1
This is a CPP action and not a CC action. This is the root of the
problem as the CPPFLAGS is not being set.
> pnglibconf.c:33:19: fatal error: zlib.h: No such file or directory
>   # include <zlib.h>
> compilation terminated.
> Makefile:2095: recipe for target 'pnglibconf.out' failed
> make: *** [pnglibconf.out] Error 1
> shell cmd failed: /bin/sh -ex
>   /home/Freenix/work/forfun/rtems/rtems-source-builder/rtems/build/libpng-v1.6.21-arm-rtems4.12-1/doit
> error: building libpng-v1.6.21-arm-rtems4.12-1
> Actually I found zlib.h is at arm-rtems4.12/mx6ulevk/lib/include/zlib.h,
> but I do not know why the directory is not in the search PATH.
The include path to the BSP headers is present in CFLAGS but there is no
CPPFLAGS defined by the RSB and we need to have the path in the
CPPFLAGS. I have a patch I am testing which adds this. Once the symbols
issue is resolved and I can test the whole process I will push the change.
