Is there any framebuffer testcases?
Joel Sherrill
joel at rtems.org
Wed Apr 13 22:07:50 UTC 2016
Peng.. do you know how to add a local patch and try that? I am happy to
push it upstream and bump the RSB to the next newlib snapshot but
we need to know it resolves a bit of the issue.
If we need to add more symbols, then now is the time.
--joel
On Wed, Apr 13, 2016 at 4:57 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 13/04/2016 17:46, Peng Fan wrote:
>> Hi Chris,
>> I met this, so I add export INCLUDES=-I%{_includedir}:
> I saw but I am concerned there is more to this. I think INCLUDES is
> specific to automake.
> arm-rtems4.12-gcc -E -DHAVE_CONFIG_H -I. -I../libpng-1.6.21 \
>> -DPNGLIB_LIBNAME='PNG16_0' -DPNGLIB_VERSION='1.6.21'
>> -DSYMBOL_PREFIX='' -DPNG_NO_USE_READ_MACROS -DPNG_BUILDING_SYMBOL_TABLE
>> pnglibconf.c > pnglibconf.tf1
> This is a CPP action and not a CC action. This is the root of the problem
> as the CPPFLAGS is not being set.
> pnglibconf.c:33:19: fatal error: zlib.h: No such file or directory
>> # include <zlib.h>
>> compilation terminated.
>> Makefile:2095: recipe for target 'pnglibconf.out' failed
>> make: *** [pnglibconf.out] Error 1
>> shell cmd failed: /bin/sh -ex
>> /home/Freenix/work/forfun/rtems/rtems-source-builder/rtems/build/libpng-v1.6.21-arm-rtems4.12-1/doit
>> error: building libpng-v1.6.21-arm-rtems4.12-1
>> Actually I found zlib.h is at arm-rtems4.12/mx6ulevk/lib/include/zlib.h,
>> but I do not know why the directory is not in the search PATH.
> The include path to the BSP headers is present in CFLAGS but there is no
> CPPFLAGS defined by the RSB and we need to have the path in the CPPFLAGS. I
> have a patch I am testing which adds this. Once the symbols issue is
> resolved and I can test the whole process I will push the change.
> Chris
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160413/d2fc0349/attachment-0001.html>
