Failure in building libxml for rtems
Sambeet Panigrahi sambeet161616 at gmail.com
Mon Aug 8 10:04:35 UTC 2016
Hi ,
I am trying to build libxml which is a dependency for Rock on rtems.I have
created the buildset file and the configuration files as mentioned in the
RSB documentation.I give the following command from my shell
$ ../source-builder/sb-set-builder --log=log_libxml_log
--prefix=/home/sambeet/NewRockPort/x86/Install/rtems/4.11.0-rc3/
--host=i386-rtems-4.11 --with-rtems-bsp=i386-rtems4.11/pc486 textproc/libxml
 and I get the output
RTEMS Source Builder - Set Builder, 4.12 (5a4af9013998 modified)
Build Set: textproc/libxml
config: textproc/libxml2-2.7.8.cfg
error: config error: rtems-bsp.cfg:27: No RTEMS target specified:
--rtems-bsp=arch/bsp (or --target=target)
Build FAILED
Build Set: Time 0:00:00.006336
Build FAILED
Even though I specified the BSP, I also tried --with-rtems-bsp=pc486 still
it gives the same error. i am also attaching the contents of the version
specific .cfg file
#LIBXML2_2.7.8 1
%if %{release} == %{nil}
 %define release 1
%endif
%include %{_configdir}/rtems-bsp.cfg
#libxml version
%define libxml_version 2.7.8
#Patch for RTEMS support
%patch add %(_patchdir)/libxml.diff
#libxml build configuration
%include %{_configdir}/libxml2-2.7.8.cfg
How can I resolve this?
Regards
Sambeet
URL: <http://lists.rtems.org/pipermail/users/attachments/20160808/4ffa3aac/attachment.html>
