undefined reference to `main' when trying to build via OMK
Joel Sherrill
joel at rtems.org
Wed Aug 17 15:03:44 UTC 2016
The main() unresolved issue is that for some reason the application is
pulling
in the default configuration in cpukit/libmisc/dummy.
This can be because the application doesn't have its own configuration
defined
or because it has a partial configuration and is missing something like say
some network or filesystem configuration.
On Wed, Aug 17, 2016 at 8:23 AM, Pavel Pisa <ppisa4lists at pikron.com> wrote:
> Hello Saeed,
> On Wednesday 17 of August 2016 11:24:12 Saeed Ehteshamifar wrote:
> > Hello,
> > I have a CPP RTEMS app that builds fine with the RTEMS Makefile but when
> I
> > try to build it via OMK, I get the following output:
> we I have not used OMK with C++ on RTEMS. So it is quite possible
> that there is some rule missing. I look at that but for integration
> into RTEMS ecosystem, you should probably try WAF or other
> RTEMS maintainers preferred system.
> Best wishes,
> Pavel
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160817/a45f2c8c/attachment-0002.html>
