undefined reference to `main' when trying to build via OMK
Saeed Ehteshamifar
salpha.2004 at gmail.com
Wed Aug 17 18:07:26 UTC 2016
I ported my app to C and it worked.
On Wed, Aug 17, 2016 at 5:03 PM, Joel Sherrill <joel at rtems.org> wrote:
> The main() unresolved issue is that for some reason the application is
> pulling
> in the default configuration in cpukit/libmisc/dummy.
> This can be because the application doesn't have its own configuration
> defined
> or because it has a partial configuration and is missing something like say
> some network or filesystem configuration.
> On Wed, Aug 17, 2016 at 8:23 AM, Pavel Pisa <ppisa4lists at pikron.com>
> wrote:
>> Hello Saeed,
>> On Wednesday 17 of August 2016 11:24:12 Saeed Ehteshamifar wrote:
>> > Hello,
>> > I have a CPP RTEMS app that builds fine with the RTEMS Makefile but
>> when I
>> > try to build it via OMK, I get the following output:
>> we I have not used OMK with C++ on RTEMS. So it is quite possible
>> that there is some rule missing. I look at that but for integration
>> into RTEMS ecosystem, you should probably try WAF or other
>> RTEMS maintainers preferred system.
>> Best wishes,
>> Pavel
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160817/a9563b98/attachment-0002.html>
