Network problem for altcycv_devkit
Adit Sahasrabudhe asahasra at fb.com
Thu Aug 25 16:13:55 UTC 2016
You will find the macro in bsp.h. If you have already installed the altcycv_devkit BSP when building rtems, then you can find it under:
<RTEMS_INSTALL>/arm-rtems4.xx/altcycv_devkit/lib/include/bsp.h
Otherwise, in the source itself:
<RTEMS_SRC>/c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h
Adit
On 8/25/16, 9:00 AM, "Jianxun Yan" <yanjx at jlab.org> wrote:
    Hi Adit,
    I couldn't  find the macro RTEMS_BSP_NETWORK_DRIVER_ATTACH in my
    rtems/bsps directory. Did I do something wrong?
    Thank you for help.
    Jay Yan
    On 08/25/2016 11:19 AM, Adit Sahasrabudhe wrote:
    > Hi Jay,
    > Please see attached file for example. The driver attach function is defined by the macro RTEMS_BSP_NETWORK_DRIVER_ATTACH inside the BSP.
    > Adit
    > On 8/25/16, 7:32 AM, "users on behalf of Jianxun Yan" <users-bounces at rtems.org on behalf of yanjx at jlab.org> wrote:
    >      Hi Sebastian,
    >      How should I configure the network? Should I use both struct
    >      rtems_bsdnet_config and rtems_bsdnet_ifconfig? Do you have any example
    >      for altcycv_devkit network?
    >      Thank you very much for your help.
    >      Jay Yan
    >      On 08/25/2016 10:18 AM, Sebastian Huber wrote:
    >      > The network interface, USB and MMC drivers are part of the libbsd for this BSP.
    >      > ----- Am 25. Aug 2016 um 15:12 schrieb Jianxun Yan yanjx at jlab.org:
    >      >> Hi,
    >      >> Since nobody answered my question, I have to post it again. Anyone can
    >      >> help me?
    >      >> Thanks,
    >      >> Jay Yan
    >      >> On 08/23/2016 11:43 AM, Jianxun Yan wrote:
    >      >>> Hi,
    >      >>> Have anyone ever ran the network application for the Altera Cyclone V
    >      >>> SoC board (BSP altcycv_devkit)? When I tried to configure the network
    >      >>> interface, I couldn't find the attach network driver. What attach
    >      >>> driver will be for RTEMS_BSP_NETWORK_DRIVER_ATTACH on the
    >      >>> Thanks,
    >      >>> Jay Yan
    >      >>> _______________________________________________
    >      >>> users mailing list
    >      >>> users at rtems.org
    >      >>> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=DQICAg&c=5VD0RTtNlTh3ycd41b3MUw&r=NQi5ZDATEqAUQ7YuH-e3LQ&m=oEFB8vuJ42tJ0BBhVxtD-j4x4Q2wnyatBXiG-d6MY7E&s=aQde8Wz_-uMJ4hPjMsoLHowSSxj2tcin5CP0na3cRSg&e=
    >      >> users mailing list
    >      >> users at rtems.org
    >      users mailing list
    >      users at rtems.org
