Unable to run sample tests
Tue Dec 20 19:44:17 UTC 2016
Perhaps you had an error in configure or make. Check the output from
those. The 'sis' was recently removed, but you should be able to use
the erc32 bsp with sparc-rtems-gdb and similar commands as the getting
started guide. Other BSPs run well on simulators, too.
After you run configure and make without errors, then you could use
the following command from your build path:
find . -name ticker.exe
To see if the ticker.exe is located anywhere in your build path, which
will indicate success.
On Mon, Dec 12, 2016 at 8:54 AM, Tanu Hari Dixit <tokencolour at gmail.com> wrote:
> Hello Devs!
> I followed the instructions given in the Getting started guide
> (https://devel.rtems.org/wiki/GSoC/GettingStarted) and
> (https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start). The latter
> says that when I bootstrap and then make and make install, I should
> find sample executables in a path similar to:
> "/home2/work/joel/rtems-4.11-work/build/build-sparc-sis-rtems/
> sparc-rtems4.11/c/sis/testsuites/samples/ticker/ticker.exe"
> I am unable to find exe files in my working directory (not even in the prefix).
> My tree is the following:
> /development/rtems/src/b-sis
> |-- sparc-rtems4.12
> |   `-- c
> |-- testsuites
> |   `-- tools
> |       `-- generic
> `-- tools
>     |-- build
>     `-- cpu
>         `-- generic
> and sparc-rtems4.12/c/ has 3 files config.log,  config.status,  Makefile
> and the directory testsuites(shown in the above tree) has no samples.
> There are samples in the rtems source directory, though
> (/development/rtems/src/rtems/testsuites/samples/ticker) but I'm
> clueless as to how to specify to test those samples. The configure
> command :
> /rtems/configure --target=sparc-rtems4.12 --enable-rtemsbsp=sis \
>   --enable-tests=samples --prefix=${HOME}/install_path
> specifies to enable tests on "samples" which I'm unable to find. How
> do I successfully run a test? Is there a mistake I did while building
> RTEMS or the RSB? Kindly help me figure this out.
> Thanking you,
> Tanu Hari Dixit,
> Senior Undergraduate,
> Department of Electronics Engineering,
> IIT BHU.
> users mailing list
> users at rtems.org
