Unable to run sample tests
Tanu Hari Dixit tokencolour at gmail.com
Mon Dec 12 13:54:31 UTC 2016
Hello Devs!
I followed the instructions given in the Getting started guide
(https://devel.rtems.org/wiki/GSoC/GettingStarted) and
(https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start). The latter
says that when I bootstrap and then make and make install, I should
find sample executables in a path similar to:
"/home2/work/joel/rtems-4.11-work/build/build-sparc-sis-rtems/
sparc-rtems4.11/c/sis/testsuites/samples/ticker/ticker.exe"
I am unable to find exe files in my working directory (not even in the prefix).
My tree is the following:
/development/rtems/src/b-sis
|-- sparc-rtems4.12
|   `-- c
|-- testsuites
|   `-- tools
|       `-- generic
`-- tools
    |-- build
    `-- cpu
        `-- generic
and sparc-rtems4.12/c/ has 3 files config.log,  config.status,  Makefile
and the directory testsuites(shown in the above tree) has no samples.
There are samples in the rtems source directory, though
(/development/rtems/src/rtems/testsuites/samples/ticker) but I'm
clueless as to how to specify to test those samples. The configure
command :
/rtems/configure --target=sparc-rtems4.12 --enable-rtemsbsp=sis \
  --enable-tests=samples --prefix=${HOME}/install_path
specifies to enable tests on "samples" which I'm unable to find. How
do I successfully run a test? Is there a mistake I did while building
RTEMS or the RSB? Kindly help me figure this out.
Thanking you,
Tanu Hari Dixit,
Senior Undergraduate,
Department of Electronics Engineering,
IIT BHU.
