SPARC floating point functions from math.h
Rehab Massoud
rehab.massoud at gmail.com
Sun Dec 11 21:31:38 UTC 2016
Thanks Joel, you're right. The std option didn't have any effect. And the
problem was in the CMake files, including -lm as a linking flag wasn't
enough. Where adding the line
target_link_libraries(my_module m) resolved the problem.
On Dec 11, 2016 22:25, "Joel Sherrill" <joel at rtems.org> wrote:
> On Dec 11, 2016 1:47 PM, "Rehab Massoud" <rehab.massoud at gmail.com> wrote:
> On Sun, Dec 11, 2016 at 8:29 PM, Joel Sherrill <joel at rtems.org> wrote:
>> What did you do to link against libm. What was the actual command line
>> for linking?
> In a cmake's CMakeCache.txt file I added -lm at the linking options. But
> this didn't work alone without the -std=c99.
> Copy and paste the generated gcc command which was invoked to link. The
> -std option really doesn't have any impact on the libm issue.
>> Best Regards,
>> Rehab
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20161211/133af3e1/attachment-0002.html>
