Can't find the ticker executable.
    Joel Sherrill
    joel at rtems.org
    Wed Dec 28 15:11:27 UTC 2016
Agreed. I was waiting to move that into the main user manual that has
been recently converted to Sphinx. But the docs need a permanent URL
before I do that.
For 4.11 and older, you should/must use sis. For newer, the simulator
can now run a real erc32 executable so we eliminated the sis BSP which
included special initialization code not needed for flight configurations.
-joel
On Wed, Dec 28, 2016 at 6:44 AM, Denis Obrezkov <denisobrezkov at gmail.com>
wrote:
> Thank you, it works. I think it would be good to change quick start
> instructions in the wiki:
> https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start
> Also, will there be problems, since we want to work with a SPARC
> Instruction Simulator (SIS) but compiled our image with erc32 bsp?
> 2016-12-28 5:07 GMT+02:00 Tanu Hari Dixit <tokencolour at gmail.com>:
>> Hey Denis,
>> Which BSP did you try? If it was sis, it has been removed from master
>> recently. You should try with erc32 with 4.12 toolchain. I had a
>> similar problem few days back and the devs pointed this out to me.
>> Regards,
>> Tanu Hari Dixit
>> On Wed, Dec 28, 2016 at 3:27 AM, Denis Obrezkov <denisobrezkov at gmail.com>
>> wrote:
>> > Hello, I've started to investigate RTEMS. I installed a toolchain, and
>> after
>> > this I executed an installation script. I followed these instructions:
>> > https://devel.rtems.org/wiki/Developer/Tools/RSB
>> > And the problem is, that I can't find the ticker executable.  There
>> were no
>> > errors during installation. Also, first time I tried to build 4.12
>> toolchain
>> > (couldn't find the ticker, removed toolchain), after that downloaded
>> 4.11
>> > toolchain and build it, again couldn't find the ticker executable.
>> > Regards, Denis Obrezkov
>> > _______________________________________________
>> > users mailing list
>> > users at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20161228/9ac72858/attachment-0002.html>
