RTEMS on Zynq Microzed
soja-lists at aries.uberspace.de
Tue Feb 2 14:57:08 UTC 2016
Hi,
I hope it's not a problem to dig up this old thread.
Am 2015-10-01 15:54, schrieb Webb, Jeffrey A.:
> That is basically the process I followed, although I used the Xilinx
> xsdk tool. (I did not know about the open source tool -- I will try
> it when I get a chance. Do you still use the Xilinx tools to generate
> the fsbl, or something else?) There seems to be a somewhat long delay
> when I boot up my RTEMS application the first time, and there is some
> issue with the serial port driver that causes missing characters at
> first. I usually push the reset button, and things clear up on
> subsequent reboots. Anyway, it sounds like there may need to be some
> changes to the bsp for the microzed, or at least some configuration
> parameters. Did you look in the BSP configure script for options like
> clock rates that may need to be changed? I had to change the
> peripheral clock configure option to get the ticker.exe tasks to run
> at the proper rate, although this didn't seems to alter the baud rate
> settings. I might be able to get my hands on a microzed, but it will
> probably be a couple weeks before I
> have time to try that.
We have the same problem with the ticker-example here.
I found the configure option for the periphal clock, but I was wondering
what value I need to set it to.
If I take a look at the clock configuration for the zync in Vivado I
get:
Input frequency: 33.333 MHz
ARMPLL : 666.666687 MHz
That seems to be in line with the standard bsp-configuration.
We also compared the settings with the same project set up for the
normal Zedboard and they look the same.
It would be a great help if you could push us in the right direction.
Cheers,
Jan
> ----- Original Message -----
>> Hi Jeff,
>> I've tried the following steps:
>> - cloned https://github.com/antmicro/zynq-mkbootimage.git
>> - create a bif file with fsbl.elf, fpga.bit, u-boot.elf (tried both
>> the
>> unstripped and stripped version of hello.exe)
>> - I renamed hello.elf into u-boot.elf and created BOOT.BIN
>> - copied BOOT.BIN to the fat partition of the microSD
>> Nothing comes out of the terminal window:I repeadetly see the blue led
>> for
>> a short period (I think is indicating the bitstream being loaded),
>> followed
>> by a shot blink of a red led.
>> Am I doing anything wrong?
>> thank you for your help,
>> Davide
>> 2015-09-30 19:49 GMT+02:00 Jeff Webb <jeff.webb at nta-inc.net>:
>> > On 09/30/2015 10:34 AM, Davide Viti wrote:
>> >> Hi,
>> >> I own a Microzed board and recently managed to boot it using buildroot
>> >> using a recent (2015.07) uboot and the Zedboard DTS shipped in the Xilinx
>> >> repository of the linux kernel.
>> >> Given the above, I assumed I cuold try RTEMS on the Microzed, using the
>> >> Zedboard BSP.
>> >> I successfully built the toolchain and the BSP (xilinx_zynq_zedboard) out
>> >> of the latest version of the git repositories and I'm trying to boot the
>> >> hello.exe sample following these steps:
>> >> arm-rtems4.11-objcopy -R -S -O binary hello.exe hello.bin
>> >> mkimage -A arm -O rtems -T kernel -C none -n "RTEMS Application" -d
>> >> hello.bin hello.img
>> >> I write the hello.img file on the microSD along with:
>> >> - BOOT.BIN
>> >> - system.bit
>> >> - u-boot-dtb.img
>> >> and u-boot starts fine:
>> >> U-Boot SPL 2015.07 (Sep 25 2015 - 09:24:38)
>> >> mmc boot
>> >> reading system.dtb
>> >> spl_load_image_fat_os: error reading image system.dtb, err - -1
>> >> reading u-boot-dtb.img
>> >> U-Boot 2015.07 (Sep 25 2015 - 09:24:38 +0200)
>> >> Model: Zynq MicroZED Board
>> >> I2C: ready
>> >> DRAM: ECC disabled 1 GiB
>> >> MMC: zynq_sdhci: 0
>> >> Using default environment
>> >> In: serial
>> >> Out: serial
>> >> Err: serial
>> >> Net: Gem.e000b000
>> >> Error: Gem.e000b000 address not set.
>> >> zynq-uboot> fatload mmc 0 0x1000000 hello.img
>> >> reading hello.img
>> >> 1039120 bytes read in 107 ms (9.3 MiB/s)
>> >> zynq-uboot> bootm 0x1000000
>> >> ## Booting kernel from Legacy Image at 01000000 ...
>> >> Image Name: RTEMS Application
>> >> Image Type: ARM RTEMS Kernel Image (uncompressed)
>> >> Data Size: 1039056 Bytes = 1014.7 KiB
>> >> Load Address: 00000000
>> >> Entry Point: 00000000
>> >> Verifying Checksum ... OK
>> >> Loading Kernel Image ... OK
>> >> ## Transferring control to RTEMS (at address 00000000) ...
>> >> Could you please give me some advices?
>> >> Are there any known success stories with this board
>> > I have RTEMS running on a ZedBoard, but I have not tried the microzed
>> > yet. I did not use u-boot, however. I built a new BOOT.BIN file using the
>> > SDK that consisted of the fsbl, fpga bitstream, and my RTEMS elf
>> > application. (Basically, I just replaced u-boot with my RTEMS
>> > application).
>> > -Jeff
>> > _______________________________________________
>> > users mailing list
>> > users at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
