Need help building RTEMS
Richard Campbell
campbrd at gmail.com
Tue Feb 16 13:17:47 UTC 2016
Yes my tools are built off of the 4.11 branch of RSB and I built RTEMS
4.11. The error message is not the only only one but it is the first.
On Mon, Feb 15, 2016 at 1:22 PM, Richard Campbell <campbrd at gmail.com> wrote:
> I am following the Quick Start instructions and have successfully built
> the toolchain and bootstrapped RTEMS but make fails when building in b-sis.
> The HEAD of b-sis/config.log:
> $ ../rtems/configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis
> --enable-tests=samples --prefix=/home/campbrd/development/rtems/4.11
> Make fails here:
> gmake[5]: Entering directory
> '/home/campbrd/development/rtems/rsb/b-sis/sparc-rtems4.11/c/sis/cpukit/libfs'
> Making all in src/nfsclient
> gmake[6]: Entering directory
> '/home/campbrd/development/rtems/rsb/b-sis/sparc-rtems4.11/c/sis/cpukit/libfs/src/nfsclient'
> sparc-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I../../..
> -I../../../../cpukit/../../../sis/lib/include
> -I../../../../../../../../rtems/c/src/../../cpukit/libfs/src/nfsclient/proto
> -UHAVE_CEXP
> -UHAVE_CEXP -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections
> -Wall -Wmissing-prototypes -Wimplicit-function-declaration
> -Wstrict-prototypes -Wnested-externs -MT src/libnfs_a-rpcio.o -MD -MP -MF
> src/.deps/libnfs_a-rpcio.Tpo -c -o src/libnfs_a-rpcio.o `test -f
> 'src/rpcio.c' || echo
> '../../../../../../../../rtems/c/src/../../cpukit/libfs/src/nfsclient/'`src/rpcio.c
> Makefile:547: recipe for target 'src/libnfs_a-rpcio.o' failed
> My development system:
> uname -a
> Linux localhost.localdomain 4.3.5-300.fc23.x86_64 #1 SMP Mon Feb 1
> 03:18:41 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
> My path when bootstrapping:
> echo $PATH
> /home/campbrd/development/rtems/4.11/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/home/campbrd/.local/bin:/home/campbrd/bin
> which autoconf
> ~/development/rtems/4.11/bin/autoconf
> which automake
> ~/development/rtems/4.11/bin/automake
> There is an rpcio.c:
> find . -name rpcio.c
> ./rtems/rsb/rtems/cpukit/libfs/src/nfsclient/src/rpcio.c
> Thanks for your help,
> Richard
URL: <http://lists.rtems.org/pipermail/users/attachments/20160216/f93e52c5/attachment.html>
