Eclipse Pluguin Problems
Simon Williams williamssimonp at gmail.com
Mon Feb 1 07:05:11 UTC 2016
My experience is that you can create empty RTEMS libraries and
applications,, but not the sample Hello World application. Creating the
Hello World application results in the situation you describe. There seems
to be some kind of issue with the template. As far as was am aware this was
always the case, I don't recall that it ever worked, but I don't remember
exactly which version of Eclipse I first used. The fact that the project
types that work are grouped under Other rather than C/C++ Application
doesn't help.
It would be nice to see the plugin brought up to date. In particular,
allowing different configurations building for different BSPs would be
useful. It is understandably not high on peoples priority list however, as
it is perfectly possible to live with it as is.
On Mon, 1 Feb 2016, 04:34 Mohammed Saeed Khoory <Mohammed.Khoory at mbrsc.ae>
wrote:
> Really? Interesting…
> A while back I tried to run the plugin with Eclipse Juno and I’ve had
> trouble creating RTEMS projects. The option for the RTEMS toolchain just
> didn’t appear, so I had to fall back to Helios.
> Is this still the case with Mars? Are you able to create new C projects
> with the RTEMS Toolchain?
> *Mohammed Saeed Khoory*
> *From:* users [mailto:users-bounces at rtems.org] *On Behalf Of *Simon
> Williams
> *Sent:* Friday, January 29, 2016 9:49 PM
> *To:* Dario Baliña; users at rtems.org
> *Subject:* Re: Eclipse Pluguin Problems
> You don't need to fall back to Galileo, I am running Mars on Fedora 23
> with no problems. The plugin doesn't seem to care! :-)
> On Fri, 29 Jan 2016, 17:17 Dario Baliña <dariosb at gmail.com> wrote:
> I have recently built a new development environment using an Centos 6.3
> machine instead Ubuntu 14.3 and the problem was solved.
> Obviously Ubuntu 14.3 and Eclipse Galileo are not working properly.
> I´m starting to get running gdb - eclipse integration, any advice or
> supporting documentation is welcome.
> thanks in advance.
> *DB.-*
> [image: View my profile on LinkedIn]
> <https://www.linkedin.com/in/dariobalina>
> 2016-01-28 12:33 GMT-03:00 Dario Baliña <dariosb at gmail.com>:
> I have chosen Galileo because is recommended in plugin installation guide
> https://devel.rtems.org/wiki/Developer/Eclipse/Plugin as the running
> version:
> The current plug-in version works with the Galileo release of Eclipse and
> CDT version 6.
> I have one more thing trying to help to clarify.
> When Ecplise starts, on the top of the workspace selection window, this
> notification appear:
> GCJ has been detected as the current Java virtual machine.  Use of GCJ is
> untested and unsupported.  Please consult the documentation for more
> Can there be any compatibility issue between Galileo and Ubuntu 14.3?
> Can you recomend another version of Eclipse to test?
> Thanks again
> *DB.-*
> 2016-01-28 12:12 GMT-03:00 Sebastian Huber <
> sebastian.huber at embedded-brains.de>:
> On 28/01/16 16:07, groups at chichak.ca wrote:
> I’d expect that the problem may be Eclipse Galileo, that came out in 2009.
> The plug-in is likely broken on newer Eclipse versions. I think I wrote
> the plug-in with the Galileo version.
> users mailing list
> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160201/c9a4ec22/attachment-0002.html>
