Crash under sparc/rtems-4.11 when compiling with FPU
Athanasios.Tsiodras at esa.int
Mon Feb 8 09:57:05 UTC 2016
(slight correction - I pasted the wrong output, the binary works fine :-)
*** BEGIN OF TEST HELLO WORLD ***
Hello World, 93647.304688
*** END OF TEST HELLO WORLD ***
I am unaware of the proper etiquette for this, so I better check - am I
allowed to edit the wiki page at
https://devel.rtems.org/wiki/TBR/UserManual/Floating_Point_Support to add
a section about Leon3 native FPU usage and the need for the patch I did in
leon3.cfg?
Apologies if I am overstepping - I just don't want others to go through
the same efforts that I did.
Kind regards,
Thanassis.
European Space Agency (via HE Space)
Thanassis Tsiodras
Real-time Embedded Software Engineer
System, Software and Technology Department
ESTEC
Keplerlaan 1, PO Box 299
NL-2200 AG Noordwijk, The Netherlands
Athanasios.Tsiodras at esa.int | www.esa.int
T +31 71 565 5332
To: "RTEMS List" <users at rtems.org>
Date: 08/02/2016 10:50
Subject: Re: Crash under sparc/rtems-4.11 when compiling with FPU
Sent by: "users" <users-bounces at rtems.org>
I verified Sebastian's suggestion - by modifying the leon3.cfg file...
diff --git a/c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg
b/c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg
index 58f2f07..30fc3a4 100644
--- a/c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg
+++ b/c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg
@@ -9,7 +9,8 @@ RTEMS_CPU_MODEL=leon3
# This contains the compiler options necessary to select the CPU
model
# and (hopefully) optimize for it.
-CPU_CFLAGS = -mcpu=cypress -msoft-float
+CPU_CFLAGS = -mcpu=cypress -mhard-float
...the generated binary of hello.exe works fine - I went a step further
and did a test calculation, too:
diff --git a/testsuites/samples/hello/init.c
b/testsuites/samples/hello/init.c
index d8fe450..6ee33f6 100644
--- a/testsuites/samples/hello/init.c
+++ b/testsuites/samples/hello/init.c
@@ -27,8 +27,13 @@ rtems_task Init(
rtems_task_argument ignored
+ int i = 0;
+ float a=3.14159f, b=1.0f;
rtems_test_begin();
- printf( "Hello World\n" );
+ for (i=0; i<10; i++)
+ b*=a;
+ printf( "Hello World, %f\n", b );
rtems_test_end();
exit( 0 );
...which worked fine:
(gdb) tar extended-remote ... ( to grmon)
(gdb) c
Continuing.
Hello World, 1.000000
...and I made sure that FPU instructions are inside:
28: 82 80 7f ff addcc %g1, -1, %g1
2c: 12 bf ff ff bne 28 <Init+0x28>
30: 91 a2 09 29 fmuls %f8, %f9, %f8
b*=a;
34: 91 a0 19 28 fstod %f8, %f8
So, executive summary.... It seems that the default compilation settings
of the Leon3 BSP forbid "real FPU" work.
If one needs to work in native (non-emulated) FPU mode, then the leon3.cfg
must be patched as I showed above.
In the long run, as Sebastian indicated, a leon3fp (and a corresponding
leon2fp, I imagine)
should ideally be added as new BSP targets - and the FPU page
(https://devel.rtems.org/wiki/TBR/UserManual/Floating_Point_Support)
should probably
be updated to indicate this.
Thanks to everyone for their help,
Thanassis.
Thanassis Tsiodras
ESTEC
T +31 71 565 5332
From: "Sebastian Huber" <sebastian.huber at embedded-brains.de>
Cc: software at gaisler.com
Date: 07/02/2016 07:40
Hello Athanasios,
it was always a miracle to me how you are supposed to use the leon2/leon3
BSPs with a FPU. If you want to use the FPU, then the BSP must be built
with the -mhard-float option, otherwise the FPU support is not enabled in
the operating system support. In addition the application configuration
must be compiled with exactly the same compiler flags as the BSP,
otherwise it will generate a corrupt configuration.
I think we need leon2fp and leon3fp BSPs, which use -mhard-float.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
This message and any attachments are intended for the use of the addressee
or addressees only.
The unauthorised disclosure, use, dissemination or copying (either in
whole or in part) of its
content is not permitted.
If you received this message in error, please notify the sender and delete
it from your system.
Emails can be altered and their integrity cannot be guaranteed by the
sender.
Please consider the environment before printing this email.
users mailing list
users at rtems.org
This message and any attachments are intended for the use of the addressee or addressees only.
The unauthorised disclosure, use, dissemination or copying (either in whole or in part) of its
If you received this message in error, please notify the sender and delete it from your system.
Emails can be altered and their integrity cannot be guaranteed by the sender.
URL: <http://lists.rtems.org/pipermail/users/attachments/20160208/23c83feb/attachment-0002.html>
