Crash under sparc/rtems-4.11 when compiling with FPU
Jiri Gaisler jiri at gaisler.se
Mon Feb 8 10:13:30 UTC 2016
We have discussed this a number of times. The reason we used
-msoft-float to compile the kernel was to avoid spurious FPU
instructions emitted by the compiler even if float/double is not used in
the C code. If this happens in a task which has not enabled FPU
operations (default), a crash will occur (FPU disabled exception). If
the current compiler version has stopped issuing spurious FPU
instructions, then the -msoft-float option can be removed, but adding
-mhard-float is not needed as this is the default.
Note also that it is probably impossible to mix non-FPU and FPU tasks in
the same kernel, at least when libm is used. Non-FPU tasks would need to
be linked against the soft-float version of libm, while FPU tasks would
need the hard-float version.
Just my two cents ...
Jiri.
On 08/02/16 10:57, Athanasios.Tsiodras at esa.int wrote:
> (slight correction - I pasted the wrong output, the binary works fine :-)
> *** BEGIN OF TEST HELLO WORLD ***
> Hello World, 93647.304688
> *** END OF TEST HELLO WORLD ***
> I am unaware of the proper etiquette for this, so I better check - am
> I allowed to edit the wiki page at
> https://devel.rtems.org/wiki/TBR/UserManual/Floating_Point_Supportto
> add a section about Leon3 native FPU usage and the need for the patch
> I did in leon3.cfg?
> Apologies if I am overstepping - I just don't want others to go
> through the same efforts that I did.
> Kind regards,
> Thanassis.
> *European Space Agency (via HE Space)*
> Thanassis Tsiodras
> Real-time Embedded Software Engineer
> System, Software and Technology Department
> *ESTEC*
> Keplerlaan 1, PO Box 299
> NL-2200 AG Noordwijk, The Netherlands
> Athanasios.Tsiodras at esa.int | www.esa.int
> T +31 71 565 5332
> From:        Athanasios.Tsiodras at esa.int
> To:        "RTEMS List" <users at rtems.org>
> Date:        08/02/2016 10:50
> Subject:        Re: Crash under sparc/rtems-4.11 when compiling with FPU
> Sent by:        "users" <users-bounces at rtems.org>
> I verified Sebastian's suggestion - by modifying the leon3.cfg file...
>    diff --git a/c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg
> b/c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg
>    index 58f2f07..30fc3a4 100644
>    --- a/c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg
>    +++ b/c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg
>    @@ -9,7 +9,8 @@ RTEMS_CPU_MODEL=leon3
>     #  This contains the compiler options necessary to select the CPU
> model
>     #  and (hopefully) optimize for it.
>    -CPU_CFLAGS = -mcpu=cypress -msoft-float
>    +CPU_CFLAGS = -mcpu=cypress -mhard-float
> ...the generated binary of hello.exe works fine - I went a step
> further and did a test calculation, too:
>    diff --git a/testsuites/samples/hello/init.c
> b/testsuites/samples/hello/init.c
>    index d8fe450..6ee33f6 100644
>    --- a/testsuites/samples/hello/init.c
>    +++ b/testsuites/samples/hello/init.c
>    @@ -27,8 +27,13 @@ rtems_task Init(
>       rtems_task_argument ignored
>    +  int i = 0;
>    +  float a=3.14159f, b=1.0f;
>       rtems_test_begin();
>    -  printf( "Hello World\n" );
>    +  for (i=0; i<10; i++)
>    +      b*=a;
>    +  printf( "Hello World, %f\n", b );
>       rtems_test_end();
>       exit( 0 );
> ...which worked fine:
>    (gdb) tar extended-remote ... ( to grmon)
>    (gdb) c
>    Continuing.
>    Hello World, 1.000000
> ...and I made sure that FPU instructions are inside:
>      28:   82 80 7f ff     addcc  %g1, -1, %g1
>      2c:   12 bf ff ff     bne  28 <Init+0x28>
>      30:   91 a2 09 29     fmuls  %f8, %f9, %f8
>          b*=a;
>      34:   91 a0 19 28     fstod  %f8, %f8
> So, executive summary....  It seems that the default compilation
> settings of the Leon3 BSP forbid "real FPU" work.
> If one needs to work in native (non-emulated) FPU mode, then the
> leon3.cfg must be patched as I showed above.
> In the long run, as Sebastian indicated, a leon3fp (and a
> corresponding leon2fp, I imagine)
> should ideally be added as new BSP targets - and the FPU page
> (_https://devel.rtems.org/wiki/TBR/UserManual/Floating_Point_Support_)
> should probably
> be updated to indicate this.
> Thanks to everyone for their help,
> Thanassis.
> Thanassis Tsiodras
> ESTEC*
> Athanasios.Tsiodras at esa.int | _www.esa.int_
> T +31 71 565 5332
> From:        "Sebastian Huber" <sebastian.huber at embedded-brains.de>
> Cc:        software at gaisler.com
> Date:        07/02/2016 07:40
> Hello Athanasios,
> it was always a miracle to me how you are supposed to use the
> leon2/leon3 BSPs with a FPU. If you want to use the FPU, then the BSP
> must be built with the -mhard-float option, otherwise the FPU support
> is not enabled in the operating system support. In addition the
> application configuration must be compiled with exactly the same
> compiler flags as the BSP, otherwise it will generate a corrupt
> configuration.
> I think we need leon2fp and leon3fp BSPs, which use -mhard-float.
> users mailing list
> users at rtems.org_
> __http://lists.rtems.org/mailman/listinfo/users_
> This message and any attachments are intended for the use of the
> addressee or addressees only.
> The unauthorised disclosure, use, dissemination or copying (either in
> whole or in part) of its
> content is not permitted.
> If you received this message in error, please notify the sender and
> delete it from your system.
> Emails can be altered and their integrity cannot be guaranteed by the
> sender.
> Please consider the environment before printing this email.
> users mailing list
> users at rtems.org
> This message and any attachments are intended for the use of the addressee or addressees only.
> The unauthorised disclosure, use, dissemination or copying (either in whole or in part) of its
> If you received this message in error, please notify the sender and delete it from your system.
> Emails can be altered and their integrity cannot be guaranteed by the sender.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160208/19dd1d17/attachment-0002.html>
