How to set up an interrupt on Zynq
    Sebastian Huber
    Tue Feb 23 20:13:25 UTC 2016
Hello,
for the interrupt API, see <bsp/irq.h> and <rtems/irq-extension.h>. For examples, search for rtems_interrupt_handler_install() in the drivers.
----- Am 23. Feb 2016 um 15:25 schrieb xuelin tian xuelin.tian at qkmtech.com:
> Hi all,I recently need to set up some interrups on Zynq via RTEMS, but I got a
> little confusing about it. In C User Manual, it says that we need
> rtems_interrupt_catch to establish an ISR for the system. But, it would go well
> when I tried it. When I dig into the source code, it shows that all the
> directives should be working based on one condition, which is
> CPU_SIMPLE_VECTORED_INTERRUPTS is TRUE. In Zynq, it is FALSE.�And, I also tried
> to configure the interrupts with the memory mapped registers as told in Zynq
> TRM, it did not go well either.�So, any general instructions on this? Thank
> you.�
> Best,TianQ.K.M Technology Co., Ltd.xuelin.tian at qkmtech.com
> users mailing list
> users at rtems.org
