RTEMS ARMv8 Query
Raghav Nayak raghav.nayak at nxp.com
Wed Feb 24 18:20:27 UTC 2016
Hey,
I am trying to build toolchain for armv8 getting following error
"configure: error: GAS does not know what format to use for target aarch64-unknown-rtems4.12"
Could anybody please help me to resolve this issue. Thanks in advance
With Regards
  Raghav
-----Original Message-----
From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On Behalf Of Gedare Bloom
Sent: Wednesday, February 24, 2016 4:55 PM
To: Raghav Nayak
Cc: Xu Ray; users at rtems.org
Subject: Re: RTEMS ARMv8 Query
On Wed, Feb 24, 2016 at 5:42 AM, Raghav Nayak <raghav.nayak at nxp.com> wrote:
> Hey Ray,
> Thanks for the info. Do you have any documentation to build toolchain
> for V8 through source builder?
RTEMS Source Builder simplifies/scripts the procedures to build the toolchain using as much as possible the upstream (gcc, newlib, binutils, etc) sources. RTEMS needs some customization in the compiler to add the -rtems target. Since support has never been added for v8, there will not be any such compiler support available yet. So the first step has to look at adding that support:
https://docs.rtems.org/doc-current/share/rtems/html/porting/index.html
