RSB fails for 4.10 and 4.9
Gerald Needell
jerry.needell at unh.edu
Fri Feb 26 17:13:14 UTC 2016
here is the full log for a 4.9 attempt.
Note for 4.11 the kernel was not actually built but I don't seem to be
able to prevent it from building for 4.9 or 4.10
On Fri, 2016-02-26 at 10:54 -0600, Joel Sherrill wrote:
> On Fri, Feb 26, 2016 at 10:36 AM, Gerald Needell
> <jerry.needell at unh.edu> wrote:
> I have been experimenting with the RTEMS Source Builder under
> CENTOS7
> 4.11 builds just fine as described on the wiki.
> I run into the same failure for 4.10 and 4.9
> ( I have gotten past the texinfo issues ...)
> The problem appears to be with git trying to download the
> rtems-kernel.
> Is there some extra step need for 4.10 or 4.9?
> Error messages:
> config: tools/rtems-kernel-4.10.2.cfg
> package: sparc-rtems4.10-kernel-4.10.2-1
> git: reset: git://git.rtems.org/rtems.git
> git: checkout: git://git.rtems.org/rtems.git => 4.10.2
> git: pull: git://git.rtems.org/rtems.git
> error: git command failed (/usr/bin/git): 1
> Build FAILED
> Are you behind a firewall that blocks git?
> Is there a log file with more detail?
> --joel
> Thanks
> Jerry
> users mailing list
> users at rtems.org
RTEMS Tools Project - Source Builder Error Report
Build: error: git command failed (/usr/bin/git): 1
Command Line: ../source-builder/sb-set-builder --log=l-sparc.txt --prefix=/home/rtems/development/rtems/4.9 4.9/rtems-sparc
Python: 2.7.5 (default, Nov 20 2015, 02:00:19) [GCC 4.8.5 20150623 (Red Hat 4.8.5-4)]
git://git.rtems.org/rtems-source-builder.git/origin/056e601477623b97ad40dfe8a3c182527bed266c
Linux rbsp-gse2.sr.unh.edu 3.10.0-327.4.4.el7.x86_64 #1 SMP Tue Jan 5 16:07:00 UTC 2016 x86_64
Tail of the build log:
make[3]: Leaving directory `/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-6.8/build/sim/testsuite'
make[3]: Entering directory `/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-6.8/build/sim/common'
/bin/sh ../../../gdb-6.8/sim/common/../../mkinstalldirs /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/man/man1
mkdir -p -- /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/man/man1
n=`echo run | sed 's,^,sparc-rtems4.9-,'`; \
/bin/install -c -m 644 ../../../gdb-6.8/sim/common/run.1 /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/man/man1/$n.1
make[3]: Leaving directory `/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-6.8/build/sim/common'
make[2]: Leaving directory `/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-6.8/build/sim'
make[2]: Entering directory `/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-6.8/build/gdb'
rm -f version.c-tmp version.c
echo '#include "version.h"' >> version.c-tmp
echo 'const char version[] = "'"`sed q ../../gdb-6.8/gdb/version.in`"'";' >> version.c-tmp
echo 'const char host_name[] = "x86_64-linux-gnu";' >> version.c-tmp
echo 'const char target_name[] = "sparc-rtems4.9";' >> version.c-tmp
mv version.c-tmp version.c
gcc -c -O2 -pipe -I/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-rtems/4.9/rtems-sparc/home/rtems/development/rtems/4.9/include -I. -I../../gdb-6.8/gdb -I../../gdb-6.8/gdb/config -DLOCALEDIR="\"/home/rtems/development/rtems/4.9/share/locale\"" -DHAVE_CONFIG_H -I../../gdb-6.8/gdb/../include/opcode -I../../gdb-6.8/gdb/../readline/.. -I../bfd -I../../gdb-6.8/gdb/../bfd -I../../gdb-6.8/gdb/../include -I../libdecnumber -I../../gdb-6.8/gdb/../libdecnumber -DMI_OUT=1 -DTUI=1 -Wall -Wdeclaration-after-statement -Wpointer-arith -Wformat-nonliteral -Wno-pointer-sign -Wno-unused -Wno-switch -Wno-char-subscripts version.c
rm -f xml-builtin.tmp
AWK="gawk" \
/bin/sh ../../gdb-6.8/gdb/features/feature_to_c.sh \
xml-builtin.tmp ../../gdb-6.8/gdb/features/gdb-target.dtd ../../gdb-6.8/gdb/features/xinclude.dtd ../../gdb-6.8/gdb/features/library-list.dtd
/bin/sh ../../gdb-6.8/gdb/../move-if-change xml-builtin.tmp xml-builtin.c
echo stamp > stamp-xml
Making init.c
/bin/sh: line 1: warning: setlocale: LC_ALL: cannot change locale (c): No such file or directory
gcc -c -O2 -pipe -I/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-rtems/4.9/rtems-sparc/home/rtems/development/rtems/4.9/include -I. -I../../gdb-6.8/gdb -I../../gdb-6.8/gdb/config -DLOCALEDIR="\"/home/rtems/development/rtems/4.9/share/locale\"" -DHAVE_CONFIG_H -I../../gdb-6.8/gdb/../include/opcode -I../../gdb-6.8/gdb/../readline/.. -I../bfd -I../../gdb-6.8/gdb/../bfd -I../../gdb-6.8/gdb/../include -I../libdecnumber -I../../gdb-6.8/gdb/../libdecnumber -DMI_OUT=1 -DTUI=1 -Wall -Wdeclaration-after-statement -Wpointer-arith -Wformat-nonliteral -Wno-pointer-sign -Wno-unused -Wno-switch -Wno-char-subscripts init.c
rm -f libgdb.a
ar q libgdb.a sparc-tdep.o ser-base.o ser-unix.o ser-pipe.o ser-tcp.o remote.o dcache.o tracepoint.o ax-general.o ax-gdb.o remote-fileio.o remote-sim.o cli-dump.o cli-decode.o cli-script.o cli-cmds.o cli-setshow.o cli-utils.o cli-logging.o cli-interp.o mi-out.o mi-console.o mi-cmds.o mi-cmd-env.o mi-cmd-var.o mi-cmd-break.o mi-cmd-stack.o mi-cmd-file.o mi-cmd-disas.o mi-symbol-cmds.o mi-cmd-target.o mi-interp.o mi-main.o mi-parse.o mi-getopt.o mi-common.o elfread.o posix-hdep.o tui-command.o tui-data.o tui-disasm.o tui-file.o tui.o tui-hooks.o tui-interp.o tui-io.o tui-layout.o tui-out.o tui-regs.o tui-source.o tui-stack.o tui-win.o tui-windata.o tui-wingeneral.o tui-winsource.o c-exp.o cp-name-parser.o objc-exp.o ada-exp.o jv-exp.o f-exp.o m2-exp.o p-exp.o version.o annotate.o addrmap.o auxv.o bfd-target.o blockframe.o breakpoint.o findvar.o regcache.o charset.o disasm.o dummy-frame.o dfp.o source.o value.o eval.o valops.o valarith.o valprint.o printcmd.o block.o symtab.o symfile.o symmisc.o linespec.o dictionary.o infcall.o infcmd.o infrun.o expprint.o environ.o stack.o thread.o exceptions.o inf-child.o interps.o main.o macrotab.o macrocmd.o macroexp.o macroscope.o event-loop.o event-top.o inf-loop.o completer.o gdbarch.o arch-utils.o gdbtypes.o osabi.o copying.o memattr.o mem-break.o target.o parse.o language.o buildsym.o std-regs.o signals.o gdb-events.o exec.o bcache.o objfiles.o observer.o minsyms.o maint.o demangle.o dbxread.o coffread.o coff-pe-read.o dwarf2read.o mipsread.o stabsread.o corefile.o dwarf2expr.o dwarf2loc.o dwarf2-frame.o ada-lang.o c-lang.o f-lang.o objc-lang.o ui-out.o cli-out.o varobj.o vec.o wrapper.o jv-lang.o jv-valprint.o jv-typeprint.o m2-lang.o p-lang.o p-typeprint.o p-valprint.o scm-exp.o scm-lang.o scm-valprint.o sentinel-frame.o complaints.o typeprint.o ada-typeprint.o c-typeprint.o f-typeprint.o m2-typeprint.o ada-valprint.o c-valprint.o cp-valprint.o f-valprint.o m2-valprint.o serial.o mdebugread.o top.o utils.o ui-file.o user-regs.o frame.o frame-unwind.o doublest.o frame-base.o gnu-v2-abi.o gnu-v3-abi.o cp-abi.o cp-support.o cp-namespace.o reggroups.o regset.o trad-frame.o tramp-frame.o solib.o solib-null.o prologue-value.o memory-map.o xml-support.o target-descriptions.o target-memory.o xml-tdesc.o xml-builtin.o inflow.o init.o
ar: creating libgdb.a
ranlib libgdb.a
rm -f gdb
gcc -O2 -pipe -I/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-rtems/4.9/rtems-sparc/home/rtems/development/rtems/4.9/include \
-o gdb gdb.o libgdb.a \
../sim/erc32/libsim.a ../readline/libreadline.a ../opcodes/libopcodes.a ../bfd/libbfd.a ../libiberty/libiberty.a ../libdecnumber/libdecnumber.a -lncurses -lm -lexpat ../libiberty/libiberty.a
rm -f gdbtui
-o gdbtui tui-main.o libgdb.a \
make[3]: Entering directory `/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-6.8/build/gdb'
make[4]: Entering directory `/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-6.8/build/gdb/doc'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-6.8/build/gdb/doc'
make[3]: Leaving directory `/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-6.8/build/gdb'
transformed_name=`t='s,^,sparc-rtems4.9-,'; \
echo gdbtui | sed -e "$t"` ; \
if test "x$transformed_name" = x; then \
transformed_name=gdbtui ; \
else \
true ; \
fi ; \
/bin/sh ../../gdb-6.8/gdb/../mkinstalldirs /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/bin ; \
/bin/install -c gdbtui \
/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/bin/$transformed_name ; \
/bin/sh ../../gdb-6.8/gdb/../mkinstalldirs \
/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/man/man1 ; \
/bin/install -c -m 644 ../../gdb-6.8/gdb/gdb.1 \
/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/man/man1/$transformed_name.1
echo gdb | sed -e "$t"` ; \
transformed_name=gdb ; \
else \
true ; \
fi ; \
/bin/install -c gdb \
(test "ln -s" = "ln -s" && \
ln -s ../../../gdb-6.8/gdb/doc/all-cfg.texi gdb-cfg.texi) || \
ln ../../../gdb-6.8/gdb/doc/all-cfg.texi gdb-cfg.texi || \
cp ../../../gdb-6.8/gdb/doc/all-cfg.texi gdb-cfg.texi
/bin/sh ../../../gdb-6.8/gdb/doc/../../mkinstalldirs /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info
/bin/install -c -m 644 ../../../gdb-6.8/gdb/doc/gdb.info /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/gdb.info
/bin/install -c -m 644 ../../../gdb-6.8/gdb/doc/gdb.info-1 /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/gdb.info-1
/bin/install -c -m 644 ../../../gdb-6.8/gdb/doc/gdb.info-2 /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/gdb.info-2
/bin/install -c -m 644 ../../../gdb-6.8/gdb/doc/gdb.info-3 /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/gdb.info-3
/bin/install -c -m 644 ../../../gdb-6.8/gdb/doc/gdb.info-4 /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/gdb.info-4
/bin/install -c -m 644 ../../../gdb-6.8/gdb/doc/gdbint.info /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/gdbint.info
/bin/install -c -m 644 ../../../gdb-6.8/gdb/doc/gdbint.info-1 /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/gdbint.info-1
/bin/install -c -m 644 ../../../gdb-6.8/gdb/doc/gdbint.info-2 /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/gdbint.info-2
/bin/install -c -m 644 ../../../gdb-6.8/gdb/doc/stabs.info /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/stabs.info
/bin/install -c -m 644 ../../../gdb-6.8/gdb/doc/annotate.info /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/annotate.info
install-info --info-dir=/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/gdb.info
install-info --info-dir=/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/gdbint.info
install-info --info-dir=/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/stabs.info
install-info --info-dir=/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/annotate.info
make[4]: Entering directory `/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-6.8/build/gdb/testsuite'
make[4]: Nothing to be done for `install'.
make[4]: Leaving directory `/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-6.8/build/gdb/testsuite'
make[2]: Leaving directory `/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-6.8/build/gdb'
make[1]: Nothing to be done for `install-target'.
make[1]: Leaving directory `/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-6.8/build'
+ rm -rf /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/configure.info
+ rm -f /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/dir
+ touch /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/info/dir
+ cd ..
+ echo '==> %clean:'
==> %clean:
copy: /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems => /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-rtems/4.9/rtems-sparc
reporting: tools/rtems-gdb-6.8-1.cfg -> sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1.txt
making dir: /home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1-root-rtems/home/rtems/development/rtems/4.9/share/rtems/rsb
reporting: tools/rtems-gdb-6.8-1.cfg -> sparc-rtems4.9-gdb-6.8-x86_64-linux-gnu-1.xml
config: tools/rtems-kernel-4.9.6-1.cfg
package: sparc-rtems4.9-kernel-4.9.6-1
script: 1: #!/bin/sh
script: 2: # ___build_pre in as set up in defaults.py
script: 3: # Save the original path away.
script: 4: export SB_ORIG_PATH=${PATH}
script: 5: # Directories
script: 6: SB_PREFIX="/home/rtems/development/rtems/4.9"
script: 7: SB_PREFIX_CLEAN=$(echo "/home/rtems/development/rtems/4.9" | /bin/sed -e 's/^\///')
script: 8: SB_SOURCE_DIR="/home/rtems/development/rtems/src/rtems-source-builder/rtems/sources"
script: 9: SB_BUILD_DIR="/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-kernel-4.9.6-1"
script: 10: # host == build, use build; host != build , host uses host and build uses build
script: 11: SB_HOST_CFLAGS="-O2 -pipe "
script: 12: SB_HOST_CXXFLAGS="-O2 -pipe "
script: 13: SB_HOST_LDFLAGS="-L/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-rtems/4.9/rtems-sparc/${SB_PREFIX_CLEAN}/lib"
script: 14: SB_BUILD_CFLAGS="-O2 -pipe -I/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-rtems/4.9/rtems-sparc/${SB_PREFIX_CLEAN}/include"
script: 15: SB_BUILD_CXXFLAGS="-O2 -pipe -I/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-rtems/4.9/rtems-sparc/${SB_PREFIX_CLEAN}/include"
script: 16: SB_BUILD_LDFLAGS="-L/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-rtems/4.9/rtems-sparc/${SB_PREFIX_CLEAN}/lib"
script: 17: SB_CFLAGS="${SB_BUILD_CFLAGS} "
script: 18: SB_CXXFLAGS="${SB_BUILD_CXXFLAGS} "
script: 19: SB_ARCH="x86_64"
script: 20: SB_OS="linux"
script: 21: export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
script: 22: export SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS
script: 23: export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS
script: 24: export SB_CFLAGS SB_CXXFLAGS
script: 25: # Documentation
script: 26: SB_DOC_DIR="/home/rtems/development/rtems/4.9/share/doc"
script: 27: export SB_DOC_DIR
script: 28: # Packages
script: 29: SB_PACKAGE_NAME="sparc-rtems4.9-kernel-4.9.6-1"
script: 30: SB_PACKAGE_BUILDNAME="sparc-rtems4.9-kernel-4.9.6-1"
script: 31: SB_PACKAGE_VERSION="4.9.6"
script: 32: SB_PACKAGE_RELEASE="1"
script: 33: export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
script: 34: # Build directories
script: 35: export SB_PREFIX
script: 36: SB_BUILD_DIR="/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-kernel-4.9.6-1"
script: 37: SB_BUILD_ROOT="/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-kernel-4.9.6-1-root-rtems"
script: 38: SB_BUILD_ROOT_BINDIR="/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-kernel-4.9.6-1-root-rtems/${SB_PREFIX_CLEAN}/bin"
script: 39: export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
script: 40: SB_BUILD_CXC_DIR="/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-kernel-4.9.6-1-cxc"
script: 41: SB_BUILD_CXC_ROOT="/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-kernel-4.9.6-1-rtems-cxc"
script: 42: SB_BUILD_CXC_ROOT_BINDIR="/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sparc-rtems4.9-kernel-4.9.6-1-rtems-cxc/${SB_PREFIX_CLEAN}/bin"
script: 43: export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
script: 44: SB_TMPROOT="/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-rtems/4.9/rtems-sparc"
script: 45: SB_TMPPREFIX="/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-rtems/4.9/rtems-sparc/${SB_PREFIX_CLEAN}"
script: 46: SB_TMPBINDIR="/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-rtems/4.9/rtems-sparc/${SB_PREFIX_CLEAN}/bin"
script: 47: export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
script: 48: SB_TMPCXCROOT="/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-rtems/4.9/rtems-sparc"
script: 49: SB_TMPCXCPREFIX="/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-rtems-cxc/4.9/rtems-sparc/${SB_PREFIX_CLEAN}"
script: 50: SB_TMPCXCBINDIR="/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/tmp/sb-rtems-cxc/4.9/rtems-sparc/${SB_PREFIX_CLEAN}/bin"
script: 51: export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
script: 52: # Extra path support
script: 53: SB_EXTRAPATH="/home/rtems/development/rtems/src/rtems-source-builder/source-builder"
script: 54: # The compiler flags
script: 55:
script: 56:
script: 57: export CFLAGS_FOR_TARGET
script: 58: export CXXFLAGS_FOR_TARGET
script: 59: # Set up the path. Put the CXC path first.
script: 60: if test -n "${SB_TMPBINDIR}" ; then
script: 61: PATH="${SB_TMPBINDIR}:$PATH"
script: 62: fi
script: 63: if test -n "${SB_TMPCXCBINDIR}" ; then
script: 64: PATH="${SB_TMPCXCBINDIR}:$PATH"
script: 65: fi
script: 66: if test -n "${SB_EXTRAPATH}" ; then
script: 67: PATH="${SB_EXTRAPATH}:$PATH"
script: 68: fi
script: 69:
script: 70:
script: 71: export PATH
script: 72: # Default environment set up.
script: 73: LANG=C
script: 74: export LANG
script: 75: unset DISPLAY || :
script: 76: umask 022
script: 77: cd "/home/rtems/development/rtems/src/rtems-source-builder/rtems/build/sparc-rtems4.9-kernel-4.9.6-1"
script: 78: echo "=> sparc-rtems4.9-kernel-4.9.6-1:"
script: 79: echo "==> %prep:"
script: 80: source_dir_rtems="rtems-4.9.6"
source setup: sparc-rtems4.9-kernel-4.9.6-1: source rtems -q -c -n sparc-rtems4.9-kernel-4.9.6-1-4.9.6
making dir: /home/rtems/development/rtems/src/rtems-source-builder/rtems/sources/git
git: clone: git://git.rtems.org/rtems.git -> sources/git/rtems.git
git: checkout: git://git.rtems.org/rtems.git => 4.9.6
