RSB fails for 4.10 and 4.9
Joel Sherrill
joel at rtems.org
Fri Feb 26 16:54:15 UTC 2016
On Fri, Feb 26, 2016 at 10:36 AM, Gerald Needell <jerry.needell at unh.edu>
wrote:
> I have been experimenting with the RTEMS Source Builder under CENTOS7
> 4.11 builds just fine as described on the wiki.
> I run into the same failure for 4.10 and 4.9
> ( I have gotten past the texinfo issues ...)
> The problem appears to be with git trying to download the rtems-kernel.
> Is there some extra step need for 4.10 or 4.9?
> Error messages:
> config: tools/rtems-kernel-4.10.2.cfg
> package: sparc-rtems4.10-kernel-4.10.2-1
> git: reset: git://git.rtems.org/rtems.git
> git: checkout: git://git.rtems.org/rtems.git => 4.10.2
> git: pull: git://git.rtems.org/rtems.git
> error: git command failed (/usr/bin/git): 1
> Build FAILED
Are you behind a firewall that blocks git?
Is there a log file with more detail?
--joel
> Thanks
> Jerry
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160226/64296fca/attachment-0002.html>
