Eclipse Pluguin Problems
Dario Baliña dariosb at gmail.com
Thu Jan 28 15:18:05 UTC 2016
Thanks for answering
If i did it, not was my intention.
I have cloned rtems repo from https://github.com/RTEMS/rtems.git, into
directory
/home/dario/development/rtems/src/rtems
After bootstrapping, I have configured target and bsp like this:
$ mkdir /development/rtems/4.11-sparc/sis
$ cd /development/rtems/4.11-sparc/sis
$ ../../src/rtems/configure –-target=sparc-rtems4.11 –-enable-rtemsbsp=sis
--enable-tests=samples –-disable-posix
I have not specified instalation point with --prefix option, and the
/opt/rtems-4.12 directory was created automatically.
Thanks
*DB.-*
<http://www.delsatgroup.com/>
[image: View my profile on LinkedIn]
<https://www.linkedin.com/in/dariobalina>
2016-01-28 12:01 GMT-03:00 Sebastian Huber <
sebastian.huber at embedded-brains.de>:
> On 28/01/16 14:49, Dario Baliña wrote:
>> Hi all
>> I have successfully installed RTEMS Toolchain using the RSB and compiled
>> and tested some demos from exmples-v2 package in two bsp´s: sparc-sis and
>> arm-lpc1768.
>> Now I am trying to get running RTEMs Plugin for Eclipse (Galileo) on an
>> Ubuntu 14.04.3 machine.
>> RTEMS pluging configuration is:
>> Base path: /opt/rtems-4.12
>> BSP path: /opt/rtems-4.12/sparc-rtems4.11/sis
> Did you mix 4.11 and 4.12 somehow?
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160128/7eb9a95a/attachment-0002.html>
