Eclipse Pluguin Problems
Gedare Bloom
gedare at rtems.org
Thu Jan 28 15:35:38 UTC 2016
Even though the 4.12 directory was created, it sounds like you have only
made 4.11 toolset? You should be certain that you are on the 4.11 branches
of all git repos (rtems-source-builder, rtems.git).
the message with /opt/rtems-4.12/bin/gcc seems a bit strange. We don't
usually see plain gcc installed into a location where RTEMS tools and OS
libs are installed.
Gedare
On Thu, Jan 28, 2016 at 10:18 AM, Dario Baliña <dariosb at gmail.com> wrote:
> Thanks for answering
> If i did it, not was my intention.
> I have cloned rtems repo from https://github.com/RTEMS/rtems.git, into
> directory
> /home/dario/development/rtems/src/rtems
> After bootstrapping, I have configured target and bsp like this:
> $ mkdir /development/rtems/4.11-sparc/sis
> $ cd /development/rtems/4.11-sparc/sis
> $ ../../src/rtems/configure –-target=sparc-rtems4.11 –-enable-rtemsbsp=sis
> --enable-tests=samples –-disable-posix
> I have not specified instalation point with --prefix option, and the
> /opt/rtems-4.12 directory was created automatically.
> Thanks
> *DB.-*
> <http://www.delsatgroup.com/>
> [image: View my profile on LinkedIn]
> <https://www.linkedin.com/in/dariobalina>
> 2016-01-28 12:01 GMT-03:00 Sebastian Huber <
> sebastian.huber at embedded-brains.de>:
>> On 28/01/16 14:49, Dario Baliña wrote:
>>> Hi all
>>> I have successfully installed RTEMS Toolchain using the RSB and compiled
>>> and tested some demos from exmples-v2 package in two bsp´s: sparc-sis and
>>> arm-lpc1768.
>>> Now I am trying to get running RTEMs Plugin for Eclipse (Galileo) on an
>>> Ubuntu 14.04.3 machine.
>>> RTEMS pluging configuration is:
>>> Base path: /opt/rtems-4.12
>>> BSP path: /opt/rtems-4.12/sparc-rtems4.11/sis
>> Did you mix 4.11 and 4.12 somehow?
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160128/74e7ed02/attachment-0002.html>
