Eclipse Pluguin Problems
Dario Baliña
dariosb at gmail.com
Thu Jan 28 15:33:41 UTC 2016
I have chosen Galileo because is recommended in plugin installation guide
https://devel.rtems.org/wiki/Developer/Eclipse/Plugin as the running
version:
The current plug-in version works with the Galileo release of Eclipse and
CDT version 6.
I have one more thing trying to help to clarify.
When Ecplise starts, on the top of the workspace selection window, this
notification appear:
GCJ has been detected as the current Java virtual machine. Use of GCJ is
untested and unsupported. Please consult the documentation for more
Can there be any compatibility issue between Galileo and Ubuntu 14.3?
Can you recomend another version of Eclipse to test?
Thanks again
*DB.-*
<http://www.delsatgroup.com/>
[image: View my profile on LinkedIn]
<https://www.linkedin.com/in/dariobalina>
2016-01-28 12:12 GMT-03:00 Sebastian Huber <
sebastian.huber at embedded-brains.de>:
> On 28/01/16 16:07, groups at chichak.ca wrote:
>> I’d expect that the problem may be Eclipse Galileo, that came out in 2009.
> The plug-in is likely broken on newer Eclipse versions. I think I wrote
> the plug-in with the Galileo version.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160128/fdef2769/attachment-0002.html>
