Eclipse Pluguin Problems
    Joel Sherrill
    joel at rtems.org
    Thu Jan 28 15:54:17 UTC 2016
On Thu, Jan 28, 2016 at 9:33 AM, Dario Baliña <dariosb at gmail.com> wrote:
> I have chosen Galileo because is recommended in plugin installation guide
> https://devel.rtems.org/wiki/Developer/Eclipse/Plugin as the running
> version:
> The current plug-in version works with the Galileo release of Eclipse and
> CDT version 6.
> I have one more thing trying to help to clarify.
> When Ecplise starts, on the top of the workspace selection window, this
> notification appear:
> GCJ has been detected as the current Java virtual machine.  Use of GCJ is
> untested and unsupported.  Please consult the documentation for more
> Can there be any compatibility issue between Galileo and Ubuntu 14.3?
My recollection is that you want "real Java" to run Eclipse. I recall
issues with GCJ.
--joel
> Can you recomend another version of Eclipse to test?
> Thanks again
> *DB.-*
> <http://www.delsatgroup.com/>
> [image: View my profile on LinkedIn]
> <https://www.linkedin.com/in/dariobalina>
> 2016-01-28 12:12 GMT-03:00 Sebastian Huber <
> sebastian.huber at embedded-brains.de>:
>> On 28/01/16 16:07, groups at chichak.ca wrote:
>>> I’d expect that the problem may be Eclipse Galileo, that came out in
>>> 2009.
>> The plug-in is likely broken on newer Eclipse versions. I think I wrote
>> the plug-in with the Galileo version.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160128/bc77e372/attachment-0002.html>
