README.configure when using master branch
Leonard Bise
leonard.bise at syderal.ch
Thu Jun 2 07:11:47 UTC 2016
Gedare, I did the help on configure but it's not documenting --enable-smp
for example so I was looking for a complete documentation. Also for example
it lists --enable-FEATURE and I was looking for the feature list.
Joel, this is mentioned in the RTEMS 4.11.99.0 documentation :
https://docs.rtems.org/doc-current/share/rtems/html/started/Using-the-RTEMS-configure-Script-Directly.html
"<TARGET> is of the form <CPU>-rtems4.12 and the list of currently
supported <TARGET> configuration’s and <BSP>’s can be found in
*tools/RTEMS-4.12.<VERSION>/README.configure**.*"
I'll take a look at the draft documentation, thank you.
*Léonard Bise*
Software Design Engineer
Direct Line +41 (0)32 338 9902
*SYDERAL SA*
Neuenburgstrasse 7
CH-3238 Gals (Switzerland)
Desk Line +41 (0)32 338 9800
Web Site http://www.syderal.ch
2016-06-01 19:31 GMT+02:00 Joel Sherrill <joel at rtems.org>:
> Where is this documented? The file was removed in anticipation of
> new getting started documentation. The current draft is here:
> https://ftp.rtems.org/pub/rtems/people/chrisj/docs/user/start/index.html
> I am sure it needs help and it is welcomed.
> --joel
> On Wed, Jun 1, 2016 at 4:24 AM, Leonard Bise <leonard.bise at syderal.ch>
> wrote:
>> In the documentation it is stated that the option that can be given to
>> configure are provided in a file called README.configure.
>> We are currently using the master branch and we cannot find this file,
>> how can we generate it for the master branch?
>> Thank you.
>> *Léonard Bise*
>> *SYDERAL SA*
>> Neuenburgstrasse 7
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160602/eb3a1cdb/attachment-0002.html>
