USE_COM1_AS_CONSOLE=1 not effective
Saeed Ehteshamifar salpha.2004 at gmail.com
Tue Jun 14 16:22:23 UTC 2016
I've just seen Gedare's problem with this also, which was unfortunately
unsolved. :(
On Tue, Jun 14, 2016 at 6:20 PM, Saeed Ehteshamifar <salpha.2004 at gmail.com>
wrote:
> Hi,
> It seems that USE_COM1_AS_CONSOLE=1 is not effective for me. I'm
> configuring RTEMS with this option (bsp: pc386) and as a result, in my BSP
> install directory (specified by --prefix), I have:
> *./i386-rtems4.12/pc386/lib/include/bspopts.h:#define USE_COM1_AS_CONSOLE
> 1*
> However, when I run the hello example, nothing is output to the screen:
> *qemu-system-i386 -kernel $(find . -name hello.exe) -serial stdio -monitor
> null -nographic*
> Below is a screenshot of QEMU, which suggests that both Console and printk
> are  using /dev/vgacons. Does this imply that the USE_COM... is taken as
> not effective?
> And how should I correctly configure RTEMS to put the output to COM1 for
> pc386?
> [image: Inline image 1]
> Thanks!
> Best Regards,
> Saeed
URL: <http://lists.rtems.org/pipermail/users/attachments/20160614/62b3043c/attachment-0002.html>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20160614/62b3043c/attachment-0002.png>
