Workflow RTEMS on Zynq Zedboard
Jan Sommer soja-lists at aries.uberspace.de
Tue Mar 22 10:16:58 UTC 2016
Am 2016-03-22 09:45, schrieb Badr El Hiouel:
> Hi Jan ,
> Thank you for support.
> It finally success! For that , I had to delete all the project, then I
> rebuild RSB and then it went very fine.
> Now , I designed a Zynq HW on Vivado and I launched it on SDK. But now
> , in
> the labs ( you sent me one for the µZed , The same exists for Zedboard
> they create a new bsp. I imagine that in this step I don't have to
> create
> one but import it from the rtems.
This part is a bit tricky. The term "bsp" is used in 2 different
contexts here.
First you have the rtems-bsp. That complements the generic parts of
rtems with the things that depend on your intended target platform (i.e.
Zedboard) like drivers for the global timer, etc. This generates the
rtems-library for your platform which is linked to your application code
to create your RTEMS-application (e.g. ticker.exe).
Then you have the bsp in the Xilinx context. The Zync CPU consists of an
ARM-CPU and an FPGA. In order to run any application on the CPU you also
have to configure the FPGA, which you do with the bsp and the FSBL from
the Xilinx-toolchain.
I don't know too much about that configuration so far. I simply followed
the tutorial where the FPGA is mainly responsible to connect the CPU to
the RAM.
In part 4 of the Tutorial for the MicroZed they build a boot image. If
you take a look at Figure 6 (p. 7), I simply replaced the
Periph_Test.elf with the test program generated by RTEMS and continued.
The setup for the normal Zedboard should be pretty similar. The
resulting boot image will boot, initialize the FPGA, load the RTEMS
program into RAM and transfer control to it.
> So, where I find the bsp ? It's a single file or a directory ? And then
> how
> can I to import it on SDK ?
> I read also that for ticker.exe we have to change the extension for
> .elfe ,
> is that what I'll have to do ?
It might be that the file dialog of the Xilinx tools expects
*.elf-files, so renaming might be necessary.
Best regards,
    Jan
PS: Please keep the rtems-users list as recipient, so other people might
join the discussion and people with the same problem might benefit.
> Thank you!
> ________
> *Badr EL HIOUEL*
> Mail : elh.badr at gmail.com
> 2016-03-19 11:57 GMT+01:00 Jan Sommer <soja-lists at aries.uberspace.de>:
>> Am Friday 18 March 2016, 17:24:48 schrieb Badr El Hiouel:
>> > > Thank you for your support,
>> > > I installed the devel environnement for Python27 and it builds (
>> finally !
>> > > When I did :
>> > > /mnt/D/development/rtems/kernel/rtems/configure --target=arm-rtems4.12
>> > > --enable-rtemsbsp=xilinx_zynq_zedboard --enable-tests=samples
>> > > --enable-posix --enable-cxx --prefix=/mnt/D/development/rtems/bsps/4.12
>> > > BSP_ARM_A9MPCORE_PERIPHCLK=333333333U
>> > > It worked but when running make && make install it shows me an error :
>> > > checking for RTEMS_CPU_MODEL...
>> > > checking for RTEMS_BSP_FAMILY... xilinx-zynq
>> > > checking for CPU_CFLAGS... (cached) -march=armv7-a -mthumb -mfpu=neon
>> > > -mfloat-abi=hard -mtune=cortex-a9
>> > > checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g -ffunction-sections
>> > > -fdata-sections
>> > > checking for style of include used by gmake... GNU
>> > > checking for arm-rtems4.12-gcc... no
>> > > configure: error: no acceptable cc found in $PATH
>> > > gmake[2]: *** [xilinx_zynq_zedboard] Error 1
>> > > gmake[2]: Leaving directory
>> > > `/mnt/D/development/rtems/kernel/zynq/arm-rtems4.12/c'
>> > > gmake[1]: *** [all-recursive] Error 1
>> > > gmake[1]: Leaving directory
>> > > make: *** [all-recursive] Error 1
>> So if I understand it correctly, the RSB finished sucessfully? Then
>> you
>> should have binaries like arm-rtems-4.12-* installed to the directory
>> you
>> passed to the RSB.
>> Configure complains that it cannot find said binaries. That is
>> probably
>> because you haven't added them to your PATH environment variable.
>> You can do that with (use the correct path to the bin-directory of
>> your
>> setup)
>> export PATH=/mnt/D/development/rtems/compiler/4.12/bin:$PATH
>> Try the configure command again after that.
>> > > It's a problem of directories ? or the configuration I did ? ( I took
>> the
>> > > same configuration you did Jan , because I have no ideas what is those
>> > > configurations and how to choose that if any body has an explanation
>> for
>> > > this part)
>> The configure command is part of the autotools and very common in the
>> Linux/Unix world when building programs from source.
>> It checks if all the dependencies are met before you build it and
>> gives
>> you the ability to configure which features of the program you want to
>> enable and where to install it.
>> > > Thank you
>> > > ________
>> > > *Badr EL HIOUEL*
>> > > 2016-03-17 23:16 GMT+01:00 Chris Johns <chrisj at rtems.org>:
>> > >> On 18/03/2016 03:12, Jan Sommer wrote:
>> > >>> Am 2016-03-17 16:31, schrieb Badr El Hiouel:
>> > >>>> I had this error that I can't found anywhere the solution for it. I
>> > >>>> attached the report bug .. Can you please tell me what is going
>> wrong ?
>> > >>> It seems to be the same error which occurs quite often here recently.
>> > >>> Apparently you need to install the python-development packet.
>> > >>> On a debian based distro it should be python-dev or libpython2.7-dev
>> > >> I have added a note about this in the up coming Getting Started Guide:
>> https://ftp.rtems.org/pub/rtems/people/chrisj/docs/user/start/index.html#development-version
>> > >> It is difficult for the RSB to track dependences for packages like
>> this.
>> > >> There are plans but they have not been implemented.
>> > >> Chris
>> > >> _______________________________________________
>> > >> users mailing list
>> > >> users at rtems.org
>> > >> http://lists.rtems.org/mailman/listinfo/users
