Linker Error on Hello
Wang, John (IVV-1800)
john.wang-1 at nasa.gov
Tue Mar 22 21:23:01 UTC 2016
Anyone know how I can fix this linker error?
/opt/rtems-4.10/bin/sparc-rtems-gcc -g -n hello.exe > hello.num
hello.exe: In function `data_start':
(.data+0x4): multiple definition of `__dso_handle'
/opt/rtems-4.10/lib/gcc/sparc-rtems/4.4.6/crtbegin.o:(.data+0x4): first defined here
hello.exe: In function `_init':
(.text+0x1e4d8): multiple definition of `_init'
/opt/rtems-4.10/lib/gcc/sparc-rtems/4.4.6/crti.o:(.init+0x0): first defined here
hello.exe: In function `BSP_fatal_return':
/opt/rtems-4.10/src/rtems-4.10/c/src/lib/libbsp/sparc/leon3/../../sparc/shared/start.S:339: multiple definition of `BSP_fatal_return'
/opt/rtems-4.10/sparc-rtems/leon3/lib/start.o:/opt/rtems-4.10/src/rtems-4.10/c/src/lib/libbsp/sparc/leon3/../../sparc/shared/start.S:339: first defined here
hello.exe: In function `CLOCK_SPEED':
/opt/rtems-4.10/src/rtems-4.10/c/src/lib/libbsp/sparc/leon3/../../sparc/shared/start.S:141: multiple definition of `CLOCK_SPEED'
/opt/rtems-4.10/sparc-rtems/leon3/lib/start.o:/opt/rtems-4.10/src/rtems-4.10/c/src/lib/libbsp/sparc/leon3/../../sparc/shared/start.S:141: first defined here
hello.exe: In function `rdb_start':
/opt/rtems-4.10/src/rtems-4.10/c/src/lib/libbsp/sparc/leon3/../../sparc/shared/start.S:141: multiple definition of `_ERC32_MEC_Timer_Control_Mirror'
hello.exe: In function `hard_reset':
/opt/rtems-4.10/src/rtems-4.10/c/src/lib/libbsp/sparc/leon3/../../sparc/shared/start.S:207: multiple definition of `hard_reset'
/opt/rtems-4.10/sparc-rtems/leon3/lib/start.o:/opt/rtems-4.10/src/rtems-4.10/c/src/lib/libbsp/sparc/leon3/../../sparc/shared/start.S:207: first defined here
hello.exe: In function `_fini':
(.text+0x1e4f4): multiple definition of `_fini'
/opt/rtems-4.10/lib/gcc/sparc-rtems/4.4.6/crti.o:(.fini+0x0): first defined here
hello.exe: In function `start':
/opt/rtems-4.10/src/rtems-4.10/c/src/lib/libbsp/sparc/leon3/../../sparc/shared/start.S:58: multiple definition of `trap_table'
/opt/rtems-4.10/sparc-rtems/leon3/lib/start.o:/opt/rtems-4.10/src/rtems-4.10/c/src/lib/libbsp/sparc/leon3/../../sparc/shared/start.S:58: first defined here
/opt/rtems-4.10/src/rtems-4.10/c/src/lib/libbsp/sparc/leon3/../../sparc/shared/start.S:141: multiple definition of `rdb_start'
/opt/rtems-4.10/src/rtems-4.10/c/src/lib/libbsp/sparc/leon3/../../sparc/shared/start.S:58: multiple definition of `start'
/opt/rtems-4.10/lib/gcc/sparc-rtems/4.4.6/crtend.o:(.dtors+0x0): multiple definition of `__DTOR_END__'
hello.exe:(.text+0x1c82c): first defined here
collect2: ld returned 1 exit status
make[5]: *** [hello.exe] Error 1
make[5]: Leaving directory `/opt/rtems-4.10build/sparc-rtems4.10/c/leon3/testsuites/samples/hello'
make[4]: *** [all-recursive] Error 1
make[4]: Leaving directory `/opt/rtems-4.10build/sparc-rtems4.10/c/leon3/testsuites/samples'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/opt/rtems-4.10build/sparc-rtems4.10/c/leon3/testsuites'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/opt/rtems-4.10build/sparc-rtems4.10/c/leon3'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/opt/rtems-4.10build/sparc-rtems4.10/c'
make: *** [all-recursive] Error 1
________________________________
Sent: Tuesday, March 22, 2016 11:35 AM
To: Wang, John (IVV-1800)
Cc: rtems-users at rtems.org
Subject: Re: collect2: ld returned 1 exit status
On Mon, Mar 21, 2016 at 11:21 PM, Wang, John (IVV-1800) <john.wang-1 at nasa.gov<mailto:john.wang-1 at nasa.gov>> wrote:
Hi,
I fixed the NM variable issue with compiling Hello for SPARC RTEMS. Now I believe I have a linker issue.
hello.exe:(.text+0x1c83c): first defined here
I don't think __DTOR_END__ has ever been declared in a start.S on any version of RTEMS for
any architecture. It is not in the start.S on the 4.10 branch of the community version. I have no
idea who added that to your version.
Do you have enough local history to see what happened?
Any ideas? Can someone help with this?
thanks
John
users mailing list
users at rtems.org<mailto:users at rtems.org>
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20160322/c3722f78/attachment.html>
