rsb for arm
Matthew Clark linux.matthew at gmail.com
Thu Mar 24 14:50:31 UTC 2016
I don't think -Wno-error will work.  It's trying to define a function twice.
Matt
On Thu, Mar 24, 2016 at 10:47 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Mar 24, 2016 at 9:16 AM, D Peter Siddons <siddons at bnl.gov> wrote:
>> Presumably so. It is Ubuntu 15.10.
> Unless someone else remembers how, we will have to wait for Chris to wake
> up.
> But I think adding -Wno-error to the build is the first work-around.
> The long term solution will be to patch the older gcc source to avoid the
> warning.
> I am sure somewhere in the gcc repository is a patch to do that.
> --joel
>> Pete.
>> On 03/24/2016 10:07 AM, Joel Sherrill wrote:
>> Is it being built with -Werror?
>> FWIW I don't see gcc 5.2.1 as an official release. I see 5.2 and 5.3. Is
>> that
>> other digit from the distribution?
>> --joel
>> On Thu, Mar 24, 2016 at 8:45 AM, D Peter Siddons <siddons at bnl.gov> wrote:
>>> Hi Matt,
>>>    I'm running gcc 5.2.1.
>>> Pete.
>>> On 03/24/2016 09:36 AM, Matthew Clark wrote:
>>>> I ran into this problem myself.  Basically, the macro that determines
>>>> the GCC version isn't working correctly, so it's defining those
>>>> functions twice.  Are you running GCC 5.x?  I had to comment out the
>>>> code for if the GCC version < 3.0.   It's kind of a pain because it
>>>> means you'll bludgeon the build process as re-running the
>>>> source-builder process will just blow out the old build folder,
>>>> extract the code fresh and you'll have the same problem.
>>>> Matt
>>>> On Thu, Mar 17, 2016 at 9:55 AM, D Peter Siddons <siddons at bnl.gov>
>>>> wrote:
>>>>> Hi Chris,
>>>>> I searched l-arm.txt for ": error" and found the lines in the attached
>>>>> file.
>>>>> Hope that helps.
>>>>>    I remember seeing something some time ago with Ubuntu. They link
>>>>> /bin/sh
>>>>> to /bin/dash instead of /bin/bash. I'm nervous about changing that in
>>>>> case
>>>>> the system relies on dash-like behaviour, but I do remember that giving
>>>>> mysterious problems once.
>>>>> Pete.
>>>>> On 03/16/2016 10:14 PM, Chris Johns wrote:
>>>>>> On 17/03/2016 12:42, D Peter Siddons wrote:
>>>>>>>     Recently upgraded from 15.04 to 15.10.
>>>>>> Ok.
>>>>>>> Report attached.
>>>>>> Hmm the error was before the report log. I never expected these level
>>>>>> of
>>>>>> warnings but building old compilers with newer ones can do this.
>>>>>> I will try and recreate the build.
>>>>>> Any chance you could peak in the log file and cut and paste the error?
>>>>>> Thanks
>>>>>> Chris
>>>>> D. Peter Siddons
>>>>> Detector Development Group Leader
>>>>> Bldg. 535B
>>>>> Photon Sciences Directorate,
>>>>> Brookhaven National Laboratory
>>>>> Upton, NY 11973
>>>>> email: siddons at bnl.gov
>>>>> Phone: (631) 344-2738
>>>>> _______________________________________________
>>>>> users mailing list
>>>>> users at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/users
>>> D. Peter Siddons
>>> Bldg. 535B
>>> Upton, NY 11973
>>> users mailing list
>>> users at rtems.org
>> D. Peter Siddons
>> Bldg. 535B
>> Upton, NY 11973
