Zynq : Manual debugging of an RTEMS demo
Thu Mar 31 01:50:24 UTC 2016
On 30/03/2016 11:45 PM, Badr El Hiouel wrote:
> I've written to XIlinx and I'm waiting their answer. But, I was looking in
> a solution of the problem so I returned back to see the the confirations
> possible when building the RTEMS BSP and I found this config :
> --enable-rtems-debug ; I didn't this when I was configuring the RTEMS BSP.
> What do this config ?
The --enable-rtems-debug option turns on some assert type checks and
some extra debugging code paths in RTEMS. It will not help here.
>Without this config can I debug RTEMS ?
Yes. It does not change how you debug RTEMS.
> Maybe this is the problem of what I'm trying to do ..
I doubt it.
