Problem building master
Mon Mar 7 17:35:33 UTC 2016
On Mon, Mar 7, 2016 at 11:15 AM, Isaac Gutekunst <isaac.gutekunst at vecna.com>
wrote:
> I think I've found some git trouble going on, so I'll give that a shot. I
> think I might have a strange hybrid of the 4.11 and 4.12 branch due to a
> nasty rebase.
Sometimes I ended up in strange situations with git also. 99% of the time
all is well
but I still screw things up occasionally.
I hope it helps.
--joel
> Isaac
> On 03/07/2016 11:54 AM, Isaac Gutekunst wrote:
>> ../rtems/configure --enable-rtemsbsp="stm32f7x" --enable-maintainer-mode
>> --disable-tests  --enable-cxx  --target=arm-rtems4.12
>> --prefix=$RTEMS/lib-rtems --disable-networking
>> Since this is still our unreleased BSP, there could be some issues
>> related to it. I'm just not sure what to look for.
>> I built GCC last week I believe.
>> Here is the --version output:
>> arm-rtems4.12-gcc (GCC) 6.0.0 20160228 (RTEMS 4.12, RSB
>> b537e5536459e207fc8e56a1df3774c1700606d5, Newlib 2.3.0.20160226)
>> Isaac
>> On 03/07/2016 11:32 AM, Joel Sherrill wrote:
>>> This is odd. I just did a fresh update and rebuilt sparc/sis with POSIX
>>> enabled.
>>> I didn't have trouble.
>>> The gcc+newlib version bumped last week but that shouldn't have had an
>>> impact
>>> yet and wouldn't have broken this. It added prototypes for a few pthread
>>> routines
>>> I am adding.
>>> How did you configure exactly?
>>> --joel
>>> On Mon, Mar 7, 2016 at 9:24 AM, Isaac Gutekunst
>>> <isaac.gutekunst at vecna.com <mailto:isaac.gutekunst at vecna.com>> wrote:
>>>     Correcting my subject typo.
>>>     On 03/07/2016 10:23 AM, Isaac Gutekunst wrote:
>>>         Hi,
>>>         I'm trying to build RTEMS master for ARM, and am getting the
>>>         following
>>>         compile error:
>>> ../../../../../../rtems/c/src/../../cpukit/libfs/src/pipe/fifo.c: In
>>>         function 'pipe_interruptible':
>>> ../../../../../../rtems/c/src/../../cpukit/libfs/src/pipe/fifo.c:76:34:
>>>         error: 'Thread_queue_Control {aka struct <anonymous>}' has no
>>> member
>>>         named 'state'
>>>              the_barrier->Barrier.Wait_queue.state |=
>>>         STATES_INTERRUPTIBLE_BY_SIGNAL;
>>> ../../../../../../rtems/c/src/../../cpukit/libfs/src/pipe/fifo.c:80:34:
>>> member
>>>         named 'state'
>>>         I can't seem to find a definition for the Barrier_Control struct,
>>>         andhaven't been able to find a root cause.
>>>         It could as always be a bootstrapping/cleaning problem where the
>>>         wrong
>>>         file is being built, but I don't think so.
>>>         Anyone know what's going on?
>>>         Thanks,
>>>         Isaac
>>>         _______________________________________________
>>>         users mailing list
>>>         users at rtems.org <mailto:users at rtems.org>
>>>         http://lists.rtems.org/mailman/listinfo/users
>>>     users mailing list
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160307/8b475f7e/attachment-0002.html>
