RSB for building 4.10
Wang, John (IVV-1800)
john.wang-1 at nasa.gov
Fri Mar 25 15:30:26 UTC 2016
Still receiving the same error.
reporting: tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg -> sparc-rtems4.10-gcc-4.4.7-newlib-1.18.0-i686-linux-gnu-1.txt
reporting: tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg -> sparc-rtems4.10-gcc-4.4.7-newlib-1.18.0-i686-linux-gnu-1.xml
config: tools/rtems-gdb-7.3.1-1.cfg
package: sparc-rtems4.10-gdb-7.3.1-i686-linux-gnu-1
warning: gdb-7.3.1.tar.gz: no hash found
building: sparc-rtems4.10-gdb-7.3.1-i686-linux-gnu-1
reporting: tools/rtems-gdb-7.3.1-1.cfg -> sparc-rtems4.10-gdb-7.3.1-i686-linux-gnu-1.txt
reporting: tools/rtems-gdb-7.3.1-1.cfg -> sparc-rtems4.10-gdb-7.3.1-i686-linux-gnu-1.xml
config: tools/rtems-kernel-4.10.2.cfg
package: sparc-rtems4.10-kernel-4.12 (29819a271950)-1
download: ftp://ftp.rtems.org/pub/rtems/releases/4.10/4.12 -> sources/rtems-4.12 (29819a271950).tar.bz2
download: ftp://ftp.rtems.org/pub/rtems/releases/4.10/4.12: error: <urlopen error ftp error: [Errno ftp error] 550 Failed to change directory.>
error: downloading (29819a271950).tar.bz2: all paths have failed, giving up
Build FAILED
See error report: rsb-report-sparc-rtems4.10-kernel-4.12 (29819a271950)-1.txt
Build Set: Time 0:41:40.693626
Build FAILED
Below is the command I used
sudo ../source-builder/sb-set-builder --prefix=$HOME/development/rtems/4.10 4.10/rtems-sparc --rtems-version=4.10
________________________________
Sent: Thursday, March 24, 2016 9:46 PM
To: Chris Johns
Cc: rtems-users at rtems.org; Wang, John (IVV-1800); Matthew Clark
Subject: Re: RSB for building 4.10
On Mar 24, 2016 7:45 PM, "Chris Johns" <chrisj at rtems.org<mailto:chrisj at rtems.org>> wrote:
> On 25/03/2016 6:24 AM, Wang, John (IVV-1800) wrote:
>> I tried what you suggested, and I am still getting the same error.
> Please add --rtems-version=4.10 to the RSB command line. Please report back if this resolves the issue.
> Changes to support releasing 4.11 may have broken something.
> FYI once 4.11 is released and I consider the master stable I will branch 4.10 and 4.9. I am not sure what will happen after that. I may just create a specific RSB releases for both branches without full 4.10 and 4.9 releases being made.
There are likely enough tickets closed on 4.10 to justify another point release.
For 4.9, I don't know.
> Thanks
> Chris
> users mailing list
> users at rtems.org<mailto:users at rtems.org>
URL: <http://lists.rtems.org/pipermail/users/attachments/20160325/76e25145/attachment-0002.html>
