No RTEMS 4.11 in RSB?
Gerald Needell jerry.needell at unh.edu
Tue May 10 13:59:22 UTC 2016
additionally, if I try to build the 4.10 bset it fails to build binutils
and it there appears to be some misconfiguration with the 4.12
toolset ...
Any suggestions?
Thanks
Jerry
[rtems at rbsp-gse2 rtems]$ ../source-builder/sb-set-builder
--log=l-sparc-4.10.txt --prefix=$HOME/sandbox/development/rtems/4.10
4.10/rtems-sparc
RTEMS Source Builder - Set Builder, 4.12 (8bcc58b249fb)
Build Set: 4.10/rtems-sparc
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-linux-gnu-1
Creating source directory: sources
download:
http://downloads.sourceforge.net/project/expat/expat/2.1.0/expat-2.1.0.tar.gz -> sources/expat-2.1.0.tar.gz
 redirect:
http://liquidtelecom.dl.sourceforge.net/project/expat/expat/2.1.0/expat-2.1.0.tar.gz
downloading: sources/expat-2.1.0.tar.gz - 549.4kB of 549.4kB (100%)
building: expat-2.1.0-x86_64-linux-gnu-1
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.txt
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.xml
config: tools/rtems-binutils-2.20.1-1.cfg
package: sparc-rtems4.12-binutils-2.20.1-x86_64-linux-gnu-1
download: ftp://ftp.gnu.org/gnu/binutils/binutils-2.20.1.tar.bz2 ->
sources/binutils-2.20.1.tar.bz2
downloading: sources/binutils-2.20.1.tar.bz2 - 16.8MB of 16.8MB (100%)
Creating source directory: patches
download:
https://git.rtems.org/rtems-tools/plain/tools/4.12/binutils/binutils-2.20.1-rtems4.10-20100826.diff -> patches/binutils-2.20.1-rtems4.10-20100826.diff
download:
https://git.rtems.org/rtems-tools/plain/tools/4.12/binutils/binutils-2.20.1-rtems4.10-20100826.diff: error: HTTP Error 404: Not found
error: downloading
https://git.rtems.org/rtems-tools/plain/tools/4.12/binutils/binutils-2.20.1-rtems4.10-20100826.diff: all paths have failed, giving up
Build FAILED
  See error report:
rsb-report-sparc-rtems4.12-binutils-2.20.1-x86_64-linux-gnu-1.txt
error: downloading
Build Set: Time 0:00:12.468130
Build FAILED
On Tue, 2016-05-10 at 13:39 +0000, Gerald Needell wrote:
> When I check for the available bsets I don't see any 4.11 bset.
> Where did it go?
> Thanks
> Jerry
> [rtems at rbsp-gse2 rtems]$ ../source-builder/sb-set-builder --list-bsets
> Examining: config
> Examining: ../source-builder/config
> Examining: ../bare/config
>     4.10/rtems-all.bset
>     4.10/rtems-arm.bset
>     4.10/rtems-autotools.bset
>     4.10/rtems-avr.bset
>     4.10/rtems-bfin.bset
>     4.10/rtems-h8300.bset
>     4.10/rtems-i386.bset
>     4.10/rtems-lm32.bset
>     4.10/rtems-m32c.bset
>     4.10/rtems-m32r.bset
>     4.10/rtems-m68k.bset
>     4.10/rtems-mips.bset
>     4.10/rtems-nios2.bset
>     4.10/rtems-powerpc.bset
>     4.10/rtems-sh.bset
>     4.10/rtems-sparc.bset
>     4.12/rtems-aarch64.bset
>     4.12/rtems-all.bset
>     4.12/rtems-arm.bset
>     4.12/rtems-autotools-base.bset
>     4.12/rtems-autotools-internal.bset
>     4.12/rtems-autotools.bset
>     4.12/rtems-bfin.bset
>     4.12/rtems-default.bset
>     4.12/rtems-epiphany.bset
>     4.12/rtems-i386.bset
>     4.12/rtems-lm32.bset
>     4.12/rtems-m32c.bset
>     4.12/rtems-m68k.bset
>     4.12/rtems-microblaze.bset
>     4.12/rtems-mips.bset
>     4.12/rtems-moxie.bset
>     4.12/rtems-nios2.bset
>     4.12/rtems-or1k.bset
>     4.12/rtems-powerpc.bset
>     4.12/rtems-sh.bset
>     4.12/rtems-sparc.bset
>     4.12/rtems-sparc64.bset
>     4.12/rtems-tools.bset
>     4.12/rtems-v850.bset
>     4.12/rtems-x86_64.bset
>     4.9/rtems-all.bset
>     4.9/rtems-arm.bset
>     4.9/rtems-autotools.bset
>     4.9/rtems-i386.bset
>     4.9/rtems-m68k.bset
>     4.9/rtems-mips.bset
>     4.9/rtems-powerpc.bset
>     4.9/rtems-sparc.bset
>     databases/sqlite.bset
>     devel/autotools-base.bset
>     devel/autotools-internal.bset
>     devel/autotools.bset
>     devel/dtc.bset
>     devel/libtool.bset
>     devel/libusb.bset
>     devel/or1ksim.bset
>     devel/qemu.bset
>     gnu-tools-4.6.bset
>     gnu-tools-4.8.2.bset
>     graphics/freetype2.bset
>     graphics/graphics-all.bset
>     graphics/libjpeg.bset
>     graphics/libpng.bset
>     graphics/libtiff.bset
>     graphics/microwindows.bset
>     graphics/nxlib.bset
>     graphics/t1lib.bset
>     lang/gcc491.bset
>     net-mgmt/net-snmp.bset
>     net/lwip.bset
>     net/ntp.bset
>     net/protobuf.bset
>     rtems-4.10-base.bset
>     rtems-4.9-base.bset
>     rtems-base.bset
>     rtems-package.bset
>     rtems-urls.bset
>     rtems-version.bset
