No RTEMS 4.11 in RSB?
Jan Sommer soja-lists at aries.uberspace.de
Tue May 10 14:30:27 UTC 2016
Am 2016-05-10 15:59, schrieb Gerald Needell:
> additionally, if I try to build the 4.10 bset it fails to build
> binutils
> and it there appears to be some misconfiguration with the 4.12
> toolset ...
> Any suggestions?
There seems to be some problems with the versioning. You can try to
comment/delete the line
%include rtems-version.bset
from rtems/config/rtems-base.bset
It looks like it overwrites the global rtems-version variable with 4.12
even if it was set to 4.10 previously.
Cheers,
    Jan
> Thanks
> Jerry
> [rtems at rbsp-gse2 rtems]$ ../source-builder/sb-set-builder
> --log=l-sparc-4.10.txt --prefix=$HOME/sandbox/development/rtems/4.10
> 4.10/rtems-sparc
> RTEMS Source Builder - Set Builder, 4.12 (8bcc58b249fb)
> Build Set: 4.10/rtems-sparc
> config: devel/expat-2.1.0-1.cfg
> package: expat-2.1.0-x86_64-linux-gnu-1
> Creating source directory: sources
> download:
> http://downloads.sourceforge.net/project/expat/expat/2.1.0/expat-2.1.0.tar.gz
> -> sources/expat-2.1.0.tar.gz
>  redirect:
> http://liquidtelecom.dl.sourceforge.net/project/expat/expat/2.1.0/expat-2.1.0.tar.gz
> downloading: sources/expat-2.1.0.tar.gz - 549.4kB of 549.4kB (100%)
> building: expat-2.1.0-x86_64-linux-gnu-1
> reporting: devel/expat-2.1.0-1.cfg ->
> expat-2.1.0-x86_64-linux-gnu-1.txt
> expat-2.1.0-x86_64-linux-gnu-1.xml
> config: tools/rtems-binutils-2.20.1-1.cfg
> package: sparc-rtems4.12-binutils-2.20.1-x86_64-linux-gnu-1
> download: ftp://ftp.gnu.org/gnu/binutils/binutils-2.20.1.tar.bz2 ->
> sources/binutils-2.20.1.tar.bz2
> downloading: sources/binutils-2.20.1.tar.bz2 - 16.8MB of 16.8MB (100%)
> Creating source directory: patches
> download:
> https://git.rtems.org/rtems-tools/plain/tools/4.12/binutils/binutils-2.20.1-rtems4.10-20100826.diff
> -> patches/binutils-2.20.1-rtems4.10-20100826.diff
> download:
> https://git.rtems.org/rtems-tools/plain/tools/4.12/binutils/binutils-2.20.1-rtems4.10-20100826.diff:
> error: HTTP Error 404: Not found
> error: downloading
> all paths have failed, giving up
> Build FAILED
>   See error report:
> rsb-report-sparc-rtems4.12-binutils-2.20.1-x86_64-linux-gnu-1.txt
> error: downloading
> Build Set: Time 0:00:12.468130
> Build FAILED
> On Tue, 2016-05-10 at 13:39 +0000, Gerald Needell wrote:
>> When I check for the available bsets I don't see any 4.11 bset.
>> Where did it go?
>> Thanks
>> Jerry
>> [rtems at rbsp-gse2 rtems]$ ../source-builder/sb-set-builder --list-bsets
>> Examining: config
>> Examining: ../source-builder/config
>> Examining: ../bare/config
>>     4.10/rtems-all.bset
>>     4.10/rtems-arm.bset
>>     4.10/rtems-autotools.bset
>>     4.10/rtems-avr.bset
>>     4.10/rtems-bfin.bset
>>     4.10/rtems-h8300.bset
>>     4.10/rtems-i386.bset
>>     4.10/rtems-lm32.bset
>>     4.10/rtems-m32c.bset
>>     4.10/rtems-m32r.bset
>>     4.10/rtems-m68k.bset
>>     4.10/rtems-mips.bset
>>     4.10/rtems-nios2.bset
>>     4.10/rtems-powerpc.bset
>>     4.10/rtems-sh.bset
>>     4.10/rtems-sparc.bset
>>     4.12/rtems-aarch64.bset
>>     4.12/rtems-all.bset
>>     4.12/rtems-arm.bset
>>     4.12/rtems-autotools-base.bset
>>     4.12/rtems-autotools-internal.bset
>>     4.12/rtems-autotools.bset
>>     4.12/rtems-bfin.bset
>>     4.12/rtems-default.bset
>>     4.12/rtems-epiphany.bset
>>     4.12/rtems-i386.bset
>>     4.12/rtems-lm32.bset
>>     4.12/rtems-m32c.bset
>>     4.12/rtems-m68k.bset
>>     4.12/rtems-microblaze.bset
>>     4.12/rtems-mips.bset
>>     4.12/rtems-moxie.bset
>>     4.12/rtems-nios2.bset
>>     4.12/rtems-or1k.bset
>>     4.12/rtems-powerpc.bset
>>     4.12/rtems-sh.bset
>>     4.12/rtems-sparc.bset
>>     4.12/rtems-sparc64.bset
>>     4.12/rtems-tools.bset
>>     4.12/rtems-v850.bset
>>     4.12/rtems-x86_64.bset
>>     4.9/rtems-all.bset
>>     4.9/rtems-arm.bset
>>     4.9/rtems-autotools.bset
>>     4.9/rtems-i386.bset
>>     4.9/rtems-m68k.bset
>>     4.9/rtems-mips.bset
>>     4.9/rtems-powerpc.bset
>>     4.9/rtems-sparc.bset
>>     databases/sqlite.bset
>>     devel/autotools-base.bset
>>     devel/autotools-internal.bset
>>     devel/autotools.bset
>>     devel/dtc.bset
>>     devel/libtool.bset
>>     devel/libusb.bset
>>     devel/or1ksim.bset
>>     devel/qemu.bset
>>     gnu-tools-4.6.bset
>>     gnu-tools-4.8.2.bset
>>     graphics/freetype2.bset
>>     graphics/graphics-all.bset
>>     graphics/libjpeg.bset
>>     graphics/libpng.bset
>>     graphics/libtiff.bset
>>     graphics/microwindows.bset
>>     graphics/nxlib.bset
>>     graphics/t1lib.bset
>>     lang/gcc491.bset
>>     net-mgmt/net-snmp.bset
>>     net/lwip.bset
>>     net/ntp.bset
>>     net/protobuf.bset
>>     rtems-4.10-base.bset
>>     rtems-4.9-base.bset
>>     rtems-base.bset
>>     rtems-package.bset
>>     rtems-urls.bset
>>     rtems-version.bset
> users mailing list
> users at rtems.org
