Zynq : Disabling cache for OCM
Sat May 21 23:39:34 UTC 2016
On 19/05/2016 6:47 PM, Sw-Hw Eng wrote:
> Hello,
> I'm porting an application to RTEMS and I was looking to a way to
> disable the L2 cache using tlb attributes. The xilinx function I want to
> use is this :
> Extern u32 MMUTable
> void Xil_SetTlbAttributes(u32 addr, u32 attrib)
> 	u32 *ptr;
> 	u32 section;
> 	section = addr / 0x100000;
> 	ptr = &MMUTable + section;
> 	*ptr = (addr & 0xFFF00000) | attrib;
> 	Xil_DCacheFlush();
> 	mtcp(XREG_CP15_INVAL_UTLB_UNLOCKED, 0);
> 	/* Invalidate all branch predictors */
> 	mtcp(XREG_CP15_INVAL_BRANCH_ARRAY, 0);
> Can you please help me on how to do this calling the mmu table under RTEMS.
Why not define the area as ARMV7_MMU_DEVICE in the MMU table to start
with? If you look into what ARMV7_MMU_DEVICE is you will see the MMU
flags used. If you do this there is no need to change the setting using
the type of code yo posted.
