build failed : ERROR : building sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1
Sagar Gupta
sagarguptamonu1996 at gmail.com
Mon Nov 7 15:45:02 UTC 2016
cmd :
* ../source-builder/sb-set-builder
--prefix=$HOME/development/rtems/4.12 4.12/rtems-sparc*>* error
*>* message in the end after 40 minutes.
*> I was trying to run the hello world program while building rsb the
following error occurred ,please help with the following error
,attached the error report >* error: building
*>* Build FAILED
*>* See error report:**
rsb-report-sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1.txt
*>* error: building sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1
*>* Build Set: Time 0:43:59.278169
* Build FAILED"*
*thanking you*
*Sagar Gupta*
URL: <http://lists.rtems.org/pipermail/users/attachments/20161107/8719728c/attachment-0001.html>
RTEMS Tools Project - Source Builder Error Report
Build: error: building sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1
Command Line: ../source-builder/sb-set-builder --prefix=/home/stark/development/rtems/4.12 4.12/rtems-sparc
Python: 2.7.6 (default, Jun 22 2015, 17:58:13) [GCC 4.8.2]
git://git.rtems.org/rtems-source-builder.git/origin/534332f22a66f16b4022e87ae50c11ff20c98dcb
Linux stark-Inspiron-3542 4.4.0-38-generic #57~14.04.1-Ubuntu SMP Tue Sep 6 17:20:43 UTC 2016 x86_64
Tail of the build log:
checking for struct reg in machine/reg.h... no
checking for struct reg.r_fs... no
checking for struct reg.r_gs... no
checking for struct user_regs_struct.fs_base... yes
checking for struct user_regs_struct.gs_base... yes
checking for PTRACE_GETREGS... yes
checking for PTRACE_GETFPXREGS... yes
checking for PT_GETDBREGS... no
checking for PT_GETXMMREGS... no
checking for struct ptrace_lwpinfo.pl_tdname... no
checking for gregset_t in sys/procfs.h... no
checking for fpregset_t in sys/procfs.h... no
checking for prgregset_t in sys/procfs.h... yes
checking for prfpregset_t in sys/procfs.h... yes
checking for prgregset32_t in sys/procfs.h... no
checking for lwpid_t in sys/procfs.h... yes
checking for psaddr_t in sys/procfs.h... yes
checking for prsysent_t in sys/procfs.h... no
checking for pr_sigset_t in sys/procfs.h... no
checking for pr_sigaction64_t in sys/procfs.h... no
checking for pr_siginfo64_t in sys/procfs.h... no
checking whether prfpregset_t type is broken... no
checking for long long support in compiler... yes
checking for long long support in printf... yes
checking for decfloat support in printf... no
checking for long double support in compiler... yes
checking for long double support in printf... yes
checking for long double support in scanf... yes
checking for the dynamic export flag... -rdynamic
checking whether <thread_db.h> has TD_NOTALLOC... yes
checking whether <thread_db.h> has TD_VERSION... yes
checking whether <thread_db.h> has TD_NOTLS... yes
checking whether ADDR_NO_RANDOMIZE is declared... yes
checking compiler warning flags... -Wall -Wpointer-arith -Wno-unused -Wunused-value -Wunused-function -Wno-switch -Wno-char-subscripts -Wempty-body -Wpointer-sign -Wmissing-prototypes -Wdeclaration-after-statement -Wmissing-parameter-type -Wold-style-declaration -Wold-style-definition -Wformat-nonliteral
checking for cygwin... no
checking for ELF support in BFD... yes
checking for library containing dlopen... (cached) -ldl
checking for Mach-O support in BFD... no
checking whether to use lzma... auto
checking for liblzma... yes
checking how to link with liblzma... -llzma
checking for X... libraries , headers
enable_sim = yes
enableval = yes
checking whether to use babeltrace... auto
checking for libbabeltrace... no
configure: WARNING: babeltrace is missing or unusable; GDB is unable to read CTF data.
configure: updating cache ./config.cache
configure: creating ./config.status
config.status: creating jit-reader.h
config.status: creating gcore
config.status: creating Makefile
config.status: creating gdb-gdb.gdb
config.status: creating doc/Makefile
config.status: creating data-directory/Makefile
config.status: creating config.h
config.status: executing depdir commands
mkdir -p -- .deps
=== configuring in testsuite (/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/gdb/testsuite)
configure: running /bin/bash ../../../gdb-7.11/gdb/testsuite/configure --disable-option-checking '--prefix=/home/stark/development/rtems/4.12' '--verbose' '--disable-nls' '--without-included-gettext' '--disable-win32-registry' '--disable-werror' '--enable-sim' '--without-zlib' '--with-expat' '--with-python' '--bindir=/home/stark/development/rtems/4.12/bin' '--exec-prefix=/home/stark/development/rtems/4.12' '--includedir=/home/stark/development/rtems/4.12/include' '--libdir=/home/stark/development/rtems/4.12/lib' '--mandir=/home/stark/development/rtems/4.12/share/man' '--infodir=/home/stark/development/rtems/4.12/share/info' '--program-transform-name=s&^&sparc-rtems4.12-&' '--build=x86_64-linux-gnu' '--host=x86_64-linux-gnu' '--target=sparc-rtems4.12' 'build_alias=x86_64-linux-gnu' 'host_alias=x86_64-linux-gnu' 'target_alias=sparc-rtems4.12' 'CC=/usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include' 'CFLAGS=-g -O2' 'LDFLAGS=-static-libstdc++ -static-libgcc -L/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/lib' 'CXX=/usr/bin/g++ -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include' 'CXXFLAGS=-g -O2' 'MAKEINFO=makeinfo --split-size=5000000' 'YACC=bison -y' --cache-file=.././config.cache --srcdir=../../../gdb-7.11/gdb/testsuite
configure: loading cache .././config.cache
checking build system type... (cached) x86_64-pc-linux-gnu
checking host system type... (cached) x86_64-pc-linux-gnu
checking target system type... (cached) sparc-unknown-rtems4.12
checking for make... (cached) make
checking whether make sets $(MAKE)... (cached) yes
checking for x86_64-linux-gnu-gcc... (cached) /usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... (cached) o
checking whether we are using the GNU C compiler... (cached) yes
checking whether /usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include accepts -g... (cached) yes
checking for /usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include option to accept ISO C89... (cached) none needed
checking how to run the C preprocessor... (cached) /usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include -E
checking for grep that handles long lines and -e... (cached) /bin/grep
checking for egrep... (cached) /bin/grep -E
checking for ANSI C header files... (cached) yes
checking for sys/types.h... (cached) yes
checking for sys/stat.h... (cached) yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking for memory.h... (cached) yes
checking for strings.h... (cached) yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking for unistd.h... (cached) yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
configure: updating cache .././config.cache
config.status: creating lib/pdtrace
make[2]: Entering directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/sim'
make[3]: Entering directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/sim/erc32'
/usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include -DHAVE_CONFIG_H -DDEFAULT_INLINE=0 -DFAST_UART -I../../../gdb-7.11/sim/erc32/../.. -I. -I../../../gdb-7.11/sim/erc32 -I../common -I../../../gdb-7.11/sim/erc32/../common -I../../include -I../../../gdb-7.11/sim/erc32/../../include -I../../bfd -I../../../gdb-7.11/sim/erc32/../../bfd -I../../opcodes -I../../../gdb-7.11/sim/erc32/../../opcodes -g -O2 -c -o sis.o -MT sis.o -MMD -MP -MF .deps/sis.Tpo ../../../gdb-7.11/sim/erc32/sis.c
rm -f tmp-hw.h
/usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include ../../../gdb-7.11/sim/erc32/../common/gentmap.c -o gentmap -g -O -I. -I../../../gdb-7.11/sim/erc32 -I../common -I../../../gdb-7.11/sim/erc32/../common -I../../include -I../../../gdb-7.11/sim/erc32/../../include -I../../bfd -I../../../gdb-7.11/sim/erc32/../../bfd -I../../opcodes -I../../../gdb-7.11/sim/erc32/../../opcodes
echo "/* generated by Makefile */" > tmp-hw.h
/bin/bash ../../../gdb-7.11/sim/erc32/../../gdb/common/create-version.sh ../../../gdb-7.11/sim/erc32/../../gdb \
x86_64-linux-gnu sparc-rtems4.12 version.c
sim_hw=""; \
for hw in $sim_hw ; do \
echo "extern const struct hw_descriptor dv_${hw}_descriptor[];" ; \
done >> tmp-hw.h
echo "const struct hw_descriptor *hw_descriptors[] = {" >> tmp-hw.h
sim_hw=""; \
echo " dv_${hw}_descriptor," ; \
done >> tmp-hw.h
echo " NULL," >> tmp-hw.h
echo "};" >> tmp-hw.h
mv tmp-hw.h hw-config.h
rm -f tmp-tvals.h tmp-tmap.c
./gentmap -h >tmp-tvals.h
/bin/bash ../../../gdb-7.11/sim/erc32/../../move-if-change tmp-tvals.h targ-vals.h
./gentmap -c >tmp-tmap.c
/bin/bash ../../../gdb-7.11/sim/erc32/../../move-if-change tmp-tmap.c targ-map.c
touch stamp-tvals
/usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include -DHAVE_CONFIG_H -DDEFAULT_INLINE=0 -DFAST_UART -I../../../gdb-7.11/sim/erc32/../.. -I. -I../../../gdb-7.11/sim/erc32 -I../common -I../../../gdb-7.11/sim/erc32/../common -I../../include -I../../../gdb-7.11/sim/erc32/../../include -I../../bfd -I../../../gdb-7.11/sim/erc32/../../bfd -I../../opcodes -I../../../gdb-7.11/sim/erc32/../../opcodes -g -O2 -c -o exec.o -MT exec.o -MMD -MP -MF .deps/exec.Tpo ../../../gdb-7.11/sim/erc32/exec.c
/usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include -DHAVE_CONFIG_H -DDEFAULT_INLINE=0 -DFAST_UART -I../../../gdb-7.11/sim/erc32/../.. -I. -I../../../gdb-7.11/sim/erc32 -I../common -I../../../gdb-7.11/sim/erc32/../common -I../../include -I../../../gdb-7.11/sim/erc32/../../include -I../../bfd -I../../../gdb-7.11/sim/erc32/../../bfd -I../../opcodes -I../../../gdb-7.11/sim/erc32/../../opcodes -g -O2 -c -o erc32.o -MT erc32.o -MMD -MP -MF .deps/erc32.Tpo ../../../gdb-7.11/sim/erc32/erc32.c
/usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include -DHAVE_CONFIG_H -DDEFAULT_INLINE=0 -DFAST_UART -I../../../gdb-7.11/sim/erc32/../.. -I. -I../../../gdb-7.11/sim/erc32 -I../common -I../../../gdb-7.11/sim/erc32/../common -I../../include -I../../../gdb-7.11/sim/erc32/../../include -I../../bfd -I../../../gdb-7.11/sim/erc32/../../bfd -I../../opcodes -I../../../gdb-7.11/sim/erc32/../../opcodes -g -O2 -c -o func.o -MT func.o -MMD -MP -MF .deps/func.Tpo ../../../gdb-7.11/sim/erc32/func.c
/usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include -DHAVE_CONFIG_H -DDEFAULT_INLINE=0 -DFAST_UART -I../../../gdb-7.11/sim/erc32/../.. -I. -I../../../gdb-7.11/sim/erc32 -I../common -I../../../gdb-7.11/sim/erc32/../common -I../../include -I../../../gdb-7.11/sim/erc32/../../include -I../../bfd -I../../../gdb-7.11/sim/erc32/../../bfd -I../../opcodes -I../../../gdb-7.11/sim/erc32/../../opcodes -g -O2 -c -o help.o -MT help.o -MMD -MP -MF .deps/help.Tpo ../../../gdb-7.11/sim/erc32/help.c
/usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include -DHAVE_CONFIG_H -DDEFAULT_INLINE=0 -DFAST_UART -I../../../gdb-7.11/sim/erc32/../.. -I. -I../../../gdb-7.11/sim/erc32 -I../common -I../../../gdb-7.11/sim/erc32/../common -I../../include -I../../../gdb-7.11/sim/erc32/../../include -I../../bfd -I../../../gdb-7.11/sim/erc32/../../bfd -I../../opcodes -I../../../gdb-7.11/sim/erc32/../../opcodes -g -O2 -c -o float.o -MT float.o -MMD -MP -MF .deps/float.Tpo ../../../gdb-7.11/sim/erc32/float.c
/usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include -DHAVE_CONFIG_H -DDEFAULT_INLINE=0 -DFAST_UART -I../../../gdb-7.11/sim/erc32/../.. -I. -I../../../gdb-7.11/sim/erc32 -I../common -I../../../gdb-7.11/sim/erc32/../common -I../../include -I../../../gdb-7.11/sim/erc32/../../include -I../../bfd -I../../../gdb-7.11/sim/erc32/../../bfd -I../../opcodes -I../../../gdb-7.11/sim/erc32/../../opcodes -g -O2 -c -o callback.o -MT callback.o -MMD -MP -MF .deps/callback.Tpo ../../../gdb-7.11/sim/erc32/../common/callback.c
/usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include -DHAVE_CONFIG_H -DDEFAULT_INLINE=0 -DFAST_UART -I../../../gdb-7.11/sim/erc32/../.. -I. -I../../../gdb-7.11/sim/erc32 -I../common -I../../../gdb-7.11/sim/erc32/../common -I../../include -I../../../gdb-7.11/sim/erc32/../../include -I../../bfd -I../../../gdb-7.11/sim/erc32/../../bfd -I../../opcodes -I../../../gdb-7.11/sim/erc32/../../opcodes -g -O2 -c -o syscall.o -MT syscall.o -MMD -MP -MF .deps/syscall.Tpo ../../../gdb-7.11/sim/erc32/../common/syscall.c
/usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include -DHAVE_CONFIG_H -DDEFAULT_INLINE=0 -DFAST_UART -I../../../gdb-7.11/sim/erc32/../.. -I. -I../../../gdb-7.11/sim/erc32 -I../common -I../../../gdb-7.11/sim/erc32/../common -I../../include -I../../../gdb-7.11/sim/erc32/../../include -I../../bfd -I../../../gdb-7.11/sim/erc32/../../bfd -I../../opcodes -I../../../gdb-7.11/sim/erc32/../../opcodes -g -O2 -c -o targ-map.o -MT targ-map.o -MMD -MP -MF .deps/targ-map.Tpo targ-map.c
/usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include -DHAVE_CONFIG_H -DDEFAULT_INLINE=0 -DFAST_UART -I../../../gdb-7.11/sim/erc32/../.. -I. -I../../../gdb-7.11/sim/erc32 -I../common -I../../../gdb-7.11/sim/erc32/../common -I../../include -I../../../gdb-7.11/sim/erc32/../../include -I../../bfd -I../../../gdb-7.11/sim/erc32/../../bfd -I../../opcodes -I../../../gdb-7.11/sim/erc32/../../opcodes -g -O2 -c -o version.o -MT version.o -MMD -MP -MF .deps/version.Tpo version.c
/usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include -DHAVE_CONFIG_H -DDEFAULT_INLINE=0 -DFAST_UART -I../../../gdb-7.11/sim/erc32/../.. -I. -I../../../gdb-7.11/sim/erc32 -I../common -I../../../gdb-7.11/sim/erc32/../common -I../../include -I../../../gdb-7.11/sim/erc32/../../include -I../../bfd -I../../../gdb-7.11/sim/erc32/../../bfd -I../../opcodes -I../../../gdb-7.11/sim/erc32/../../opcodes -g -O2 -c -o interf.o -MT interf.o -MMD -MP -MF .deps/interf.Tpo ../../../gdb-7.11/sim/erc32/interf.c
/usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include -DHAVE_CONFIG_H -DDEFAULT_INLINE=0 -DFAST_UART -I../../../gdb-7.11/sim/erc32/../.. -I. -I../../../gdb-7.11/sim/erc32 -I../common -I../../../gdb-7.11/sim/erc32/../common -I../../include -I../../../gdb-7.11/sim/erc32/../../include -I../../bfd -I../../../gdb-7.11/sim/erc32/../../bfd -I../../opcodes -I../../../gdb-7.11/sim/erc32/../../opcodes -g -O2 -c -o run.o -MT run.o -MMD -MP -MF .deps/run.Tpo ../../../gdb-7.11/sim/erc32/run.c
/usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include -DHAVE_CONFIG_H -DDEFAULT_INLINE=0 -DFAST_UART -I../../../gdb-7.11/sim/erc32/../.. -I. -I../../../gdb-7.11/sim/erc32 -I../common -I../../../gdb-7.11/sim/erc32/../common -I../../include -I../../../gdb-7.11/sim/erc32/../../include -I../../bfd -I../../../gdb-7.11/sim/erc32/../../bfd -I../../opcodes -I../../../gdb-7.11/sim/erc32/../../opcodes -g -O2 -o sis \
sis.o exec.o erc32.o func.o help.o float.o ../../bfd/libbfd.a ../../opcodes/libopcodes.a ../../libiberty/libiberty.a -ldl -lnsl -L../../zlib -lz ../../readline/libreadline.a -lm
rm -f libsim.a
x86_64-linux-gnu-ar rc libsim.a callback.o syscall.o targ-map.o version.o exec.o erc32.o func.o help.o float.o interf.o
x86_64-linux-gnu-ranlib libsim.a
/usr/bin/gcc -O2 -pipe -I/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/include -DHAVE_CONFIG_H -DDEFAULT_INLINE=0 -DFAST_UART -I../../../gdb-7.11/sim/erc32/../.. -I. -I../../../gdb-7.11/sim/erc32 -I../common -I../../../gdb-7.11/sim/erc32/../common -I../../include -I../../../gdb-7.11/sim/erc32/../../include -I../../bfd -I../../../gdb-7.11/sim/erc32/../../bfd -I../../opcodes -I../../../gdb-7.11/sim/erc32/../../opcodes -g -O2 -static-libstdc++ -static-libgcc -L/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/tmp/sb-stark/4.12/rtems-sparc/home/stark/development/rtems/4.12/lib -o run \
run.o libsim.a ../../bfd/libbfd.a ../../opcodes/libopcodes.a ../../libiberty/libiberty.a -ldl -lnsl -L../../zlib -lz ../../readline/libreadline.a -lm
../../readline/libreadline.a(display.o): In function `cr':
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/display.c:2486: undefined reference to `tputs'
../../readline/libreadline.a(display.o): In function `_rl_move_cursor_relative':
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/display.c:1985: undefined reference to `tputs'
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/display.c:2014: undefined reference to `tputs'
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/display.c:2018: undefined reference to `tputs'
../../readline/libreadline.a(display.o): In function `_rl_move_vert':
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/display.c:2057: undefined reference to `tputs'
../../readline/libreadline.a(display.o):/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/display.c:2073: more undefined references to `tputs' follow
../../readline/libreadline.a(display.o): In function `insert_some_chars':
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/display.c:2390: undefined reference to `tgoto'
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/display.c:2391: undefined reference to `tputs'
../../readline/libreadline.a(display.o): In function `delete_chars':
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/display.c:2433: undefined reference to `tgoto'
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/display.c:2434: undefined reference to `tputs'
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/display.c:2407: undefined reference to `tputs'
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/display.c:2416: undefined reference to `tputs'
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/display.c:2400: undefined reference to `tputs'
../../readline/libreadline.a(display.o): In function `rl_redisplay':
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/display.c:1087: undefined reference to `tputs'
../../readline/libreadline.a(display.o):/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/display.c:2535: more undefined references to `tputs' follow
../../readline/libreadline.a(terminal.o): In function `_rl_get_screen_size':
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:278: undefined reference to `tgetnum'
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:297: undefined reference to `tgetnum'
../../readline/libreadline.a(terminal.o): In function `_rl_init_terminal_io':
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:527: undefined reference to `PC'
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:528: undefined reference to `BC'
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:529: undefined reference to `UP'
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:481: undefined reference to `tgetent'
../../readline/libreadline.a(terminal.o): In function `get_term_capabilities':
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:427: undefined reference to `tgetstr'
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:538: undefined reference to `PC'
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:539: undefined reference to `BC'
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:540: undefined reference to `UP'
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:545: undefined reference to `tgetflag'
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:560: undefined reference to `tgetflag'
../../readline/libreadline.a(terminal.o): In function `_rl_backspace':
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:665: undefined reference to `tputs'
../../readline/libreadline.a(terminal.o): In function `rl_ding':
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:703: undefined reference to `tputs'
../../readline/libreadline.a(terminal.o): In function `_rl_enable_meta_key':
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:729: undefined reference to `tputs'
../../readline/libreadline.a(terminal.o): In function `_rl_control_keypad':
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:741: undefined reference to `tputs'
../../readline/libreadline.a(terminal.o): In function `_rl_set_cursor':
/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:767: undefined reference to `tputs'
../../readline/libreadline.a(terminal.o):/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/readline/../../gdb-7.11/readline/terminal.c:765: more undefined references to `tputs' follow
collect2: error: ld returned 1 exit status
make[3]: *** [sis] Error 1
make[3]: *** Waiting for unfinished jobs....
make[3]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/sim/erc32'
make[2]: *** [all] Error 1
make[2]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build/sim'
make[1]: *** [all-sim] Error 2
make[1]: Leaving directory `/home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/build'
make: *** [all] Error 2
shell cmd failed: /bin/sh -ex /home/stark/development/rtems/rsb/rtems-source-builder/rtems/build/sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1/doit
