build failed : ERROR : building sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1
Joel Sherrill
joel at rtems.org
Mon Nov 7 17:10:23 UTC 2016
The tputs symbol is part of curses. On CentOS, RHEL, and Fedora,
this should take care of it.
sudo yum install ncurses-devel
On other distributions, the package will have a similar name.
--joel
On Mon, Nov 7, 2016 at 9:45 AM, Sagar Gupta <sagarguptamonu1996 at gmail.com>
wrote:
> cmd :
> * ../source-builder/sb-set-builder --prefix=$HOME/development/rtems/4.12 4.12/rtems-sparc*>* error
> *>* message in the end after 40 minutes.
> *> I was trying to run the hello world program while building rsb the following error occurred ,please help with the following error ,attached the error report >* error: building sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1
> *>* Build FAILED
> *>* See error report:** rsb-report-sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1.txt
> *>* error: building sparc-rtems4.12-gdb-7.11-x86_64-linux-gnu-1
> *>* Build Set: Time 0:43:59.278169
> * Build FAILED"*
> *thanking you*
> *Sagar Gupta*
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20161107/2a2f0027/attachment-0002.html>
