rtems-addon-packages removed?
Matt Rippa
mrippa at gemini.edu
Thu Nov 10 17:30:15 UTC 2016
Hi Joel,
I'm trying to build rtems-4.10.2 strictly with rsb. When it comes to the
rtems-addon packages it's not clear there's any build set to accomplish
this. As a work around I cloned git://git.rtems.org/rtems-addon-packages.git
and switched to the rtems-addon-packages-4-10-branch. Building this works
fine except the libbspExt package is missing. This is required for us to
build EPICS.
To proceed with a 4.10.2 install for EPICS, I had to:
1. $ cd rtems-addon
2. $ wget --passive-ftp --no-directories --retr-symlinks
www.slac.stanford.edu/~strauman/rtems/rtems_libbspExt_1.5.tgz
3. unpack, make, make install
4. rebuild EPICS
Is there a known rsb build-set for 4.10.2 or even a git branch for 4.10.2
that includes libbspExt_1_5?
-Matt
On Sat, Oct 1, 2016 at 5:09 AM, Joel Sherrill <joel at rtems.org> wrote:
> I'm going to dig back through my sent email. I know I worked on them.
> Maybe I sent them to the list or Chris directly for review and they never
> got merged.
> On Oct 1, 2016 9:08 AM, "Michael Westfall" <mwestfal at gemini.edu> wrote:
> But the rtems-addon-packages had things like ncurses, readline and
> libtecla..
> Are those somewhere in RSB now?
> On Sat, Oct 1, 2016 at 4:42 AM, Chris Johns <chrisj at rtems.org> wrote:
>> On 1/10/16 3:04 am, Gedare Bloom wrote:
>> > On Fri, Sep 30, 2016 at 11:57 AM, Joel Sherrill <joel at rtems.org> wrote:
>> >> On Sep 30, 2016 10:49 AM, "Gedare Bloom" <gedare at rtems.org> wrote:
>> >>> Looks like it was renamed: https://git.rtems.org/libbsdport/
>> >> That's the port of newer drivers to the old tcpip stack.
>> >>> Also, https://devel.rtems.org/ticket/2469 indicates some progress
>> was made
>> >>> to convert it to RSB configurations/recipes, after which the git repo
>> would
>> >>> become obsolete.
>> >> That's the reason. You can build them all with the rsb. The graphics
>> toolkit
>> >> has only a couple of packages left and it follows the same fate.
>> > Where are the recipes in the RSB? A quick look was not obvious.
>> https://git.rtems.org/rtems-source-builder/tree/rtems/config/graphics
>> which means names like:
>> graphics/tllib
>> graphics/microwindows
>> Chris
>> users mailing list
>> users at rtems.org
> Mike Westfall
> Control Systems Software Engineer
> users mailing list
> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20161110/e87768bf/attachment.html>
