rtems-addon-packages removed?
Thu Nov 10 18:16:58 UTC 2016
On Thu, Nov 10, 2016 at 11:30 AM, Matt Rippa <mrippa at gemini.edu> wrote:
> Hi Joel,
> I'm trying to build rtems-4.10.2 strictly with rsb. When it comes to the
> rtems-addon packages it's not clear there's any build set to accomplish
> this. As a work around I cloned git://git.rtems.org/rte
> ms-addon-packages.git and switched to the rtems-addon-packages-4-10-branch.
> Building this works fine except the libbspExt package is missing. This is
> required for us to build EPICS.
libbspExt was never part of RTEMS. It was developed atSLAC. I found this:
https://github.com/epicsdeb/rtems-libbspext
And this is where it originated.
http://www.slac.stanford.edu/~strauman/rtems/software.html
If there is a newer version, I don't know.  It was always a SLAC/EPICS
addon.
It is a good candidate for an RSB recipe.
> To proceed with a 4.10.2 install for EPICS, I had to:
> 1. $ cd rtems-addon
> 2. $ wget --passive-ftp --no-directories --retr-symlinks
> www.slac.stanford.edu/~strauman/rtems/rtems_libbspExt_1.5.tgz
> 3. unpack, make, make install
> 4. rebuild EPICS
> Is there a known rsb build-set for 4.10.2 or even a git branch for 4.10.2
> that includes libbspExt_1_5?
> The SLAC link I posted has 1.5 and 1.6.
Good opportunity to create an RSB recipe and submit it. It would be
appreciated.
FWIW one for EPICS itself would be awesome and appreciated.
> -Matt
> On Sat, Oct 1, 2016 at 5:09 AM, Joel Sherrill <joel at rtems.org> wrote:
>> I'm going to dig back through my sent email. I know I worked on them.
>> Maybe I sent them to the list or Chris directly for review and they never
>> got merged.
>> On Oct 1, 2016 9:08 AM, "Michael Westfall" <mwestfal at gemini.edu> wrote:
>> But the rtems-addon-packages had things like ncurses, readline and
>> libtecla..
>> Are those somewhere in RSB now?
>> On Sat, Oct 1, 2016 at 4:42 AM, Chris Johns <chrisj at rtems.org> wrote:
>>> On 1/10/16 3:04 am, Gedare Bloom wrote:
>>> > On Fri, Sep 30, 2016 at 11:57 AM, Joel Sherrill <joel at rtems.org>
>>> wrote:
>>> >> On Sep 30, 2016 10:49 AM, "Gedare Bloom" <gedare at rtems.org> wrote:
>>> >>> Looks like it was renamed: https://git.rtems.org/libbsdport/
>>> >> That's the port of newer drivers to the old tcpip stack.
>>> >>> Also, https://devel.rtems.org/ticket/2469 indicates some progress
>>> was made
>>> >>> to convert it to RSB configurations/recipes, after which the git
>>> repo would
>>> >>> become obsolete.
>>> >> That's the reason. You can build them all with the rsb. The graphics
>>> toolkit
>>> >> has only a couple of packages left and it follows the same fate.
>>> > Where are the recipes in the RSB? A quick look was not obvious.
>>> https://git.rtems.org/rtems-source-builder/tree/rtems/config/graphics
>>> which means names like:
>>>  graphics/tllib
>>>  graphics/microwindows
>>> Chris
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
>> Mike Westfall
>> Control Systems Software Engineer
>> users mailing list
>> users at rtems.org
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20161110/d07fede7/attachment-0002.html>
