rtems-addon-packages removed?
Joel Sherrill
joel at rtems.org
Thu Nov 10 19:25:59 UTC 2016
On Thu, Nov 10, 2016 at 1:17 PM, Matt Rippa <mrippa at gemini.edu> wrote:
> Thanks for the info. Any reason why the rtems-libbspext couldn't live on
> git.rtems.org ? I think this link exists mostly for Michael's
> epics/debian distribution.
> The main one is practical. Do the maintainer(s) want to maintain it here?
Another question to ask is what capabilities are in that library and should
they be a standard part of the BSP interfaces? If they are that useful, it
would be nice to encourage them on all BSPs, not just the ones the EPICS
community uses.
> Anyway, looks like I have enough to make an RSB recipe.
Great!
> -Matt
> On Thu, Nov 10, 2016 at 8:16 AM, Joel Sherrill <joel at rtems.org> wrote:
>> On Thu, Nov 10, 2016 at 11:30 AM, Matt Rippa <mrippa at gemini.edu> wrote:
>>> Hi Joel,
>>> I'm trying to build rtems-4.10.2 strictly with rsb. When it comes to the
>>> rtems-addon packages it's not clear there's any build set to accomplish
>>> this. As a work around I cloned git://git.rtems.org/rte
>>> ms-addon-packages.git and switched to the rtems-addon-packages-4-10-branch.
>>> Building this works fine except the libbspExt package is missing. This is
>>> required for us to build EPICS.
>> libbspExt was never part of RTEMS. It was developed atSLAC. I found this:
>> https://github.com/epicsdeb/rtems-libbspext
>> And this is where it originated.
>> http://www.slac.stanford.edu/~strauman/rtems/software.html
>> If there is a newer version, I don't know. It was always a SLAC/EPICS
>> addon.
>> It is a good candidate for an RSB recipe.
>>> To proceed with a 4.10.2 install for EPICS, I had to:
>>> 1. $ cd rtems-addon
>>> 2. $ wget --passive-ftp --no-directories --retr-symlinks
>>> www.slac.stanford.edu/~strauman/rtems/rtems_libbspExt_1.5.tgz
>>> 3. unpack, make, make install
>>> 4. rebuild EPICS
>>> Is there a known rsb build-set for 4.10.2 or even a git branch for
>>> 4.10.2 that includes libbspExt_1_5?
>>> The SLAC link I posted has 1.5 and 1.6.
>> Good opportunity to create an RSB recipe and submit it. It would be
>> appreciated.
>> FWIW one for EPICS itself would be awesome and appreciated.
>>> -Matt
>>> On Sat, Oct 1, 2016 at 5:09 AM, Joel Sherrill <joel at rtems.org> wrote:
>>>> I'm going to dig back through my sent email. I know I worked on them.
>>>> Maybe I sent them to the list or Chris directly for review and they never
>>>> got merged.
>>>> On Oct 1, 2016 9:08 AM, "Michael Westfall" <mwestfal at gemini.edu> wrote:
>>>> But the rtems-addon-packages had things like ncurses, readline and
>>>> libtecla..
>>>> Are those somewhere in RSB now?
>>>> On Sat, Oct 1, 2016 at 4:42 AM, Chris Johns <chrisj at rtems.org> wrote:
>>>>> On 1/10/16 3:04 am, Gedare Bloom wrote:
>>>>> > On Fri, Sep 30, 2016 at 11:57 AM, Joel Sherrill <joel at rtems.org>
>>>>> wrote:
>>>>> >> On Sep 30, 2016 10:49 AM, "Gedare Bloom" <gedare at rtems.org> wrote:
>>>>> >>> Looks like it was renamed: https://git.rtems.org/libbsdport/
>>>>> >> That's the port of newer drivers to the old tcpip stack.
>>>>> >>> Also, https://devel.rtems.org/ticket/2469 indicates some progress
>>>>> was made
>>>>> >>> to convert it to RSB configurations/recipes, after which the git
>>>>> repo would
>>>>> >>> become obsolete.
>>>>> >> That's the reason. You can build them all with the rsb. The
>>>>> graphics toolkit
>>>>> >> has only a couple of packages left and it follows the same fate.
>>>>> > Where are the recipes in the RSB? A quick look was not obvious.
>>>>> https://git.rtems.org/rtems-source-builder/tree/rtems/config/graphics
>>>>> which means names like:
>>>>> graphics/tllib
>>>>> graphics/microwindows
>>>>> Chris
>>>>> _______________________________________________
>>>>> users mailing list
>>>>> users at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/users
>>>> Mike Westfall
>>>> Control Systems Software Engineer
>>>> users mailing list
>>>> users at rtems.org
>>>> users mailing list
>>>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20161110/898e808a/attachment.html>
