ERROR : git command failed (/usr/bin/git): 128
Joel Sherrill
joel at rtems.org
Fri Nov 11 17:16:00 UTC 2016
On Nov 11, 2016 11:11 AM, "Sagar Gupta" <sagarguptamonu1996 at gmail.com>
wrote:
> I was trying to run the hello world program while building rsb the
following error occurred ,please help with the following error ,attached
the error report
> >git: fetch: git://git.rtems.org/rtems-tools.git ->
sources/git/rtems-tools.git
> >error: git command failed (/usr/bin/git): 128
> >Build FAILED
> > See error report: rsb-report-rtems-tools-HEAD-1.txt
> >Build Set: Time 0:52:13.515762
> >Build FAILED
Can you do a git of rtems-tools by hand? 128 just means git failed. Often
due to odd network issues including firewalls blocking protocols.
It can also just be spurious.
Let's see if there is a firewall issue first.
> thanking you
> Sagar Gupta
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20161111/8fe908d7/attachment.html>
