Building rtems toolchain with fortran support error
Joel Sherrill
joel at rtems.org
Mon Nov 21 20:09:05 UTC 2016
Following up again. So far a handful of architectures have built OK for
me but you were unlucky enough to try the one that failed -- i386:
/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/i386-rtems4.12-gcc-6-20161110-newlib-2.4.0.20161025-x86_64-linux-gnu-1/gcc-6-20161110/newlib/libc/include/ieeefp.h:152:2:
error: #error "double and long double are the same size but LDBL_EQ_DBL is
not defined"
#error "double and long double are the same size but LDBL_EQ_DBL is not
defined"
Following up on newlib about this.
--joel
On Mon, Nov 21, 2016 at 12:51 PM, Joel Sherrill <joel at rtems.org> wrote:
> Please update your RSB and try again. I successfully built a SPARC 4.12
> toolset using the current RSB master.
> Please follow up and let us know what happens.
> -joel
> On Mon, Nov 21, 2016 at 9:24 AM, Ricardo Derbes <rmderbes at gmail.com>
> wrote:
>> Hello.
>> I'm trying to build rtems toolchain for i386 using
>> rtems-source-builder with fortran support (--with-fortran option).
>> The RSB I'm using has been dowloaded from git, commit
>> 534332f22a66f16b4022e87ae50c11ff20c98dcb from Sep 12 2016.
>> The full command line is:
>> ../source-builder/sb-set-builder
>> --prefix=~/devel4.12-i386.fortran/rtems4.12 4.12/rtems-i386
>> --without-rtems --with-fortran
>> When trying to build gcc, it fails with the following errors (excerpt
>> from report file
>> rsb-report-i386-rtems4.12-gcc-6-20160609-newlib-2.4.0.201605
>> 27-x86_64-linux-gnu-1.txt):
>> Tail of the build log:
>> ~/devel4.12-i386.fortran/rtems-source-builder/rtems/build/
>> i386-rtems4.12-gcc-6-20160609-newlib-2.4.0.20160527-x86_64-
>> linux-gnu-1/gcc-6-20160609/newlib/libc/include/ieeefp.h:196:38:
>> error: 'EXT_FRACHBITS' undeclared here (not in a function)
>> __ieee_ext_field_type ext_frach : EXT_FRACHBITS;
>> linux-gnu-1/gcc-6-20160609/newlib/libc/include/ieeefp.h:196:26:
>> error: bit-field 'ext_frach' width not an integer constant
>> /home/dev/devel4.12-i386.fortran/rtems-source-builder/rtems/
>> build/i386-rtems4.12-gcc-6-20160609-newlib-2.4.0.20160527
>> -x86_64-linux-gnu-1/gcc-6-20160609/newlib/libc/include/ieeefp.h:197:3:
>> error: unknown type name '__ieee_ext_field_type'
>> __ieee_ext_field_type ext_exp : EXT_EXPBITS;
>> linux-gnu-1/gcc-6-20160609/newlib/libc/include/ieeefp.h:197:38:
>> error: 'EXT_EXPBITS' undeclared here (not in a function)
>> -x86_64-linux-gnu-1/gcc-6-20160609/newlib/libc/include/ieeefp.h:197:26:
>> error: bit-field 'ext_exp' width not an integer constant
>> linux-gnu-1/gcc-6-20160609/newlib/libc/include/ieeefp.h:198:3:
>> __ieee_ext_field_type ext_sign : 1;
>> As for my application I need fortran support, how can I fix this problem?
>> As long I can see, all symbols that the compiler claims as undeclared
>> are indeed declared and accessible in file
>> May be it's missing a symbol, e.g a proper value for LDBL_MANT_DIG ?
>> Thank you
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20161121/5c887de3/attachment-0001.html>
