Building rtems toolchain with fortran support error
Ricardo Derbes rmderbes at gmail.com
Tue Nov 22 13:27:59 UTC 2016
Thank you for your support.
I will continue investigating further.
Regards
Ricardo
2016-11-21 17:09 GMT-03:00 Joel Sherrill <joel at rtems.org>:
> Following up again. So far a handful of architectures have built OK for
> me but you were unlucky enough to try the one that failed -- i386:
> /home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/i386-rtems4.12-gcc-6-20161110-newlib-2.4.0.20161025-x86_64-linux-gnu-1/gcc-6-20161110/newlib/libc/include/ieeefp.h:152:2:
> error: #error "double and long double are the same size but LDBL_EQ_DBL is
> not defined"
>  #error "double and long double are the same size but LDBL_EQ_DBL is not
> defined"
> Following up on newlib about this.
> --joel
> On Mon, Nov 21, 2016 at 12:51 PM, Joel Sherrill <joel at rtems.org> wrote:
>> Please update your RSB and try again. I successfully built a SPARC 4.12
>> toolset using the current RSB master.
>> Please follow up and let us know what happens.
>> -joel
>> On Mon, Nov 21, 2016 at 9:24 AM, Ricardo Derbes <rmderbes at gmail.com>
>> wrote:
>>> Hello.
>>> I'm trying to build rtems toolchain for i386 using
>>> rtems-source-builder with fortran support (--with-fortran option).
>>> The RSB I'm using has been dowloaded from git, commit
>>> 534332f22a66f16b4022e87ae50c11ff20c98dcb from Sep 12 2016.
>>> The full command line is:
>>> ../source-builder/sb-set-builder
>>> --prefix=~/devel4.12-i386.fortran/rtems4.12 4.12/rtems-i386
>>> --without-rtems --with-fortran
>>> When trying to build gcc, it fails with the following errors (excerpt
>>> from report file
>>> rsb-report-i386-rtems4.12-gcc-6-20160609-newlib-2.4.0.20160527-x86_64-linux-gnu-1.txt):
>>> Tail of the build log:
>>> ~/devel4.12-i386.fortran/rtems-source-builder/rtems/build/i386-rtems4.12-gcc-6-20160609-newlib-2.4.0.20160527-x86_64-linux-gnu-1/gcc-6-20160609/newlib/libc/include/ieeefp.h:196:38:
>>> error: 'EXT_FRACHBITS' undeclared here (not in a function)
>>> __ieee_ext_field_type  ext_frach : EXT_FRACHBITS;
>>> ~/devel4.12-i386.fortran/rtems-source-builder/rtems/build/i386-rtems4.12-gcc-6-20160609-newlib-2.4.0.20160527-x86_64-linux-gnu-1/gcc-6-20160609/newlib/libc/include/ieeefp.h:196:26:
>>> error: bit-field 'ext_frach' width not an integer constant
>>> /home/dev/devel4.12-i386.fortran/rtems-source-builder/rtems/build/i386-rtems4.12-gcc-6-20160609-newlib-2.4.0.20160527-x86_64-linux-gnu-1/gcc-6-20160609/newlib/libc/include/ieeefp.h:197:3:
>>> error: unknown type name '__ieee_ext_field_type'
>>>    __ieee_ext_field_type  ext_exp   : EXT_EXPBITS;
>>> ~/devel4.12-i386.fortran/rtems-source-builder/rtems/build/i386-rtems4.12-gcc-6-20160609-newlib-2.4.0.20160527-x86_64-linux-gnu-1/gcc-6-20160609/newlib/libc/include/ieeefp.h:197:38:
>>> error: 'EXT_EXPBITS' undeclared here (not in a function)
>>> /home/dev/devel4.12-i386.fortran/rtems-source-builder/rtems/build/i386-rtems4.12-gcc-6-20160609-newlib-2.4.0.20160527-x86_64-linux-gnu-1/gcc-6-20160609/newlib/libc/include/ieeefp.h:197:26:
>>> error: bit-field 'ext_exp' width not an integer constant
>>> ~/devel4.12-i386.fortran/rtems-source-builder/rtems/build/i386-rtems4.12-gcc-6-20160609-newlib-2.4.0.20160527-x86_64-linux-gnu-1/gcc-6-20160609/newlib/libc/include/ieeefp.h:198:3:
>>> __ieee_ext_field_type  ext_sign  : 1;
>>> As for my application I need fortran support, how can I fix this problem?
>>> As long I can see, all symbols that the compiler claims as undeclared
>>> are indeed declared and accessible in file
>>> May be it's missing a symbol, e.g a proper value for LDBL_MANT_DIG ?
>>> Thank you
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
