rtems_task_wake_after doubles the actual period
Tue Oct 11 05:06:49 UTC 2016
a9mpcore_clock_periphclk() is a weak function. Simply provide an
implementation for it returning the right value in your application.
On 11/10/16 06:35, xuelin.tian at qkmtech.com wrote:
> Dear all,
> When I used rtems_task_wake_after function to delay like 10s,
> (rtems_task_wake_after(1000), the default tick is 10ms), the actual
> period was incorrect, which doubled the set value. Then I checked the
> <bspopts.h>, and modified the BSP_ARM_A9MPCORE_PERIPHCLK value without
> rebuilding RTEMS . But nothing chaned.
> So, do I need to modify the corresponding value in <configure.ac>, and
> rebuild my BSP? Or, is there other way to correct this bug without
> modifying the value and rebuilding the code?
> Best wishes,
> Tim Tian
> users mailing list
> users at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
