Follow-up: RTEMS Project Documentation repository available.
Gene Smith gds at chartertn.net
Fri Sep 9 06:24:17 UTC 2016
On 09/09/2016 12:14 AM, Chris Johns wrote:
> On 09/09/2016 13:40, Chris Johns wrote:
>>> line 251, in fatal
>>>       raise self.errors.ConfigurationError(msg,ex=ex)
>>> ConfigurationError: Working folders given to tasks must be Node objects
>>> Any ideas? (waf works OK when running RSB or example-v2 apps).
>> Thank you for testing and reporting. It seems something in waf-1.9.3 has
>> changed and exposed an issue in the doc build system. Amar put the build
>> system together and I am not sure what has broken.
> I have pushed a patch which fixes the issue. Please pull and try again.
> Thanks
> Chris
Pulling rtems-doc project brought in your fix and now
$ waf
builds the html with no error (but one warning; see below).
However, I get the same crash error as before if I do
$ waf --pdf
[gene at hplt eclipse]$ waf --pdf
Waf: Entering directory `/home/gene/rtems/rtems-docs/eclipse/build'
[1/1] Processing latex/eclipse.tex: glossary.rst index.rst overview.rst
rtems.rst -> build/latex/eclipse.tex
Waf: Leaving directory `/home/gene/rtems/rtems-docs/eclipse/build'
Build failed
Traceback (most recent call last):
   File
"/home/gene/bin/.waf-1.9.3-81a83addbb9dd6b696b76d32d6fa8a8e/waflib/Task.py",
line 138, in process
     ret=self.run()
   File "<string>", line 6, in f
   File
line 94, in get_cwd
     self.generator.bld.fatal('Working folders given to tasks must be
Node objects')
   File
"/home/gene/bin/.waf-1.9.3-81a83addbb9dd6b696b76d32d6fa8a8e/waflib/Context.py",
line 251, in fatal
Not sure if this is because of a missing package (texlive-*). Configure
tells me I have program "pdflatex" (seem needed for pdf's) but I don't
have programs exlatex, makeglossaries and inlinear.
Also, the first time I ran waf after your update it emitted this warning:
WARNING: sphinx.ext.pngmath has been deprecated. Please use
sphinx.ext.imgmath instead.
Don't know what this means.
-gene
