Follow-up: RTEMS Project Documentation repository available.
Fri Sep 9 04:14:03 UTC 2016
On 09/09/2016 13:40, Chris Johns wrote:
>> line 251, in fatal
>>       raise self.errors.ConfigurationError(msg,ex=ex)
>> ConfigurationError: Working folders given to tasks must be Node objects
>> Any ideas? (waf works OK when running RSB or example-v2 apps).
> Thank you for testing and reporting. It seems something in waf-1.9.3 has
> changed and exposed an issue in the doc build system. Amar put the build
> system together and I am not sure what has broken.
I have pushed a patch which fixes the issue. Please pull and try again.
Thanks
