Ubuntu .. Re: sparc-gdb not compiling
Joel Sherrill
joel at rtems.org
Fri Sep 30 17:29:57 UTC 2016
Any Ubuntu users want to jump in. Please.
On Sep 30, 2016 12:27 PM, "Agostino" <agostino.mascitti at student.univaq.it>
wrote:
Dear Joel,
I saw notes for Ubuntu. And this is the report
agostino at agostino-X555LJ:~/development/chronos/linux-3.0.24-chronos$ sudo
apt-get install python2.7-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
python2.7-dev is already the newest version (2.7.12-1~16.04).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
apt-get build-dep binutils gcc g++ gdb unzip git
E: Unable to find a source package for binutils
Moreover, I also tried to download expat and libexpat1. This is the report:
apt-get install libexpat1
[sudo] password for agostino:
libexpat1 is already the newest version (2.1.0-7ubuntu0.16.04.2).
This means that when I tried to compile, I have already had expat.
Could you assist me?
I am downloading Ubuntu 16.04 64 bit. Hope it will work correctly now and
that it will download binutils!
Thank you for your assistence.
Best regards,
Agostino
On ven, set 30, 2016 at 4:54 , Joel Sherrill <joel at rtems.org> wrote:
I think it is in the libexpat1 package. Use apt to search for which package
has the library and install it.
There should be notes for Ubuntu in the RSB docs. A patch for Elementary
distribution advice would be appreciated
--joel
On Sep 30, 2016 9:12 AM, "Agostino" <agostino.mascitti at student.univaq.it>
wrote:
> Hi all,
> I am under Elementary OS 64 bit last version. I get the error in
> attachment as error while compiling sparc-gdb and I cannot solve it alone.
> Best regards,
> Agostino
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160930/3a3880a4/attachment.html>
