Ubuntu .. Re: sparc-gdb not compiling
D Peter Siddons
siddons at bnl.gov
Fri Sep 30 18:09:51 UTC 2016
Hi Agostino,
Looking through the rsb output I saw a few things which got a "no"
answer, which might cause problems.
checking for library containing kinfo_getvmmap... no
checking for libexpat... no
checking libunwind-ia64.h usability... no
checking libunwind-ia64.h presence... no
checking for libunwind-ia64.h... no
I'm not an rsb expert, but maybe you need the -dev versions, so try installing libunwind-dev and libexpat-dev. I couldn't find anything about kinfo_getvmmap, but maybe a little googling will uncover something.
Pete.
On 09/30/2016 01:29 PM, Joel Sherrill wrote:
> Any Ubuntu users want to jump in. Please.
> On Sep 30, 2016 12:27 PM, "Agostino"
> <agostino.mascitti at student.univaq.it
> <mailto:agostino.mascitti at student.univaq.it>> wrote:
> Dear Joel,
> I saw notes for Ubuntu. And this is the report
> agostino at agostino-X555LJ:~/development/chronos/linux-3.0.24-chronos$
> sudo apt-get install python2.7-dev
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> python2.7-dev is already the newest version (2.7.12-1~16.04).
> 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
> sudo apt-get build-dep binutils gcc g++ gdb unzip git
> E: Unable to find a source package for binutils
> Moreover, I also tried to download expat and libexpat1. This is
> the report:
> sudo apt-get install libexpat1
> [sudo] password for agostino:
> libexpat1 is already the newest version (2.1.0-7ubuntu0.16.04.2).
> This means that when I tried to compile, I have already had expat.
> Could you assist me?
> I am downloading Ubuntu 16.04 64 bit. Hope it will work correctly
> now and that it will download binutils!
> Thank you for your assistence.
> Best regards,
> Agostino
> On ven, set 30, 2016 at 4:54 , Joel Sherrill <joel at rtems.org
> <mailto:joel at rtems.org>> wrote:
>> I think it is in the libexpat1 package. Use apt to search for
>> which package has the library and install it.
>> There should be notes for Ubuntu in the RSB docs. A patch for
>> Elementary distribution advice would be appreciated
>> --joel
>> On Sep 30, 2016 9:12 AM, "Agostino"
>> Hi all,
>> I am under Elementary OS 64 bit last version. I get the error
>> in attachment as error while compiling sparc-gdb and I cannot
>> solve it alone.
>> Best regards,
>> Agostino
>> users mailing list
>> users at rtems.org <mailto:users at rtems.org>
>> <http://lists.rtems.org/mailman/listinfo/users>
> users mailing list
> users at rtems.org
D. Peter Siddons
Detector Development Group Leader
Bldg. 535B
Photon Sciences Directorate,
Brookhaven National Laboratory
Upton, NY 11973
email: siddons at bnl.gov
Phone: (631) 344-2738
URL: <http://lists.rtems.org/pipermail/users/attachments/20160930/26471e58/attachment.html>
